#965: Location wizard: doesn't create MYNAME
Reporter: hamish | Owner: martinl
Type: defect | Status: reopened
Priority: normal | Milestone: 6.4.1
Component: wxGUI | Version: svn-releasebranch64
Resolution: | Keywords: location wizard
Platform: All | Cpu: All
Comment(by hamish):
Hamish:
> > TypeError: create_location() got an unexpected keyword argument 'desc'
Martin:
> your pythonlib is probably out-dated. Please run svn up & make in
lib/python.
yes, that was it. works now.
I suggest to add a tooltip to the "Location title:" in the loc wiz to
clarify that the title is descriptive text and another to the "Project
location:" to clarify that that one is the real name that it will go by.
It seems like it could get confused.
> question: why need to be description of the location only one-line text
for grass 6 this is part of the specification for LOCATION file tree and
should not be changed. at the low level G_myname() only reads 1 line of
text for the location title.
> and moreover limited to the given number of chars.
simply a function of the buffer size used in G_myname()
> I guess that this limitation broken in GRASS7.
yes, but anything that uses G_myname() would have to be changed too.
Currently it is the 1 line ''title'' of the location, not full metadata
story about it. So it is used for example as the long map title in ps.map
if you ask for an automatic header.
moreover the entire metadata system for grass7 needs to be overhauled, and
this is one part of that.
> > perhaps wrongly applied, but G_myname() is using GNAME_MAX for the
> > max length (256 chars in gis.h) of the description.
> yes, GNAME_MAX could be replaced by GPATH_MAX (or new GTITLE_MAX) to
enlarge the
> buffer.
what I meant was that GNAME_MAX is meant for map names, not arbitrary
strings of text. If random things are using it which shouldn't be, we get
afraid to change it later even if the change is safe for the intended map
names. GPATH_MAX is abusing it even more, the loc title has nothing to do
with filesystem limits. For a single line description I think 256 chars is
appropriate, just not to hijack defined constants meant for another
purpose. RECORD_LEN would actually be more appropriate, but for grass 6
that's stuck at 80 chars. meh, so I guess just leave this as-is.
thanks,
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/965#comment:8>
