[GRASS-dev] [GRASS GIS] #969: move color structs to colors.h?
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
     Type: task | Status: new
Component: Display | Version: svn-trunk
Keywords: RGBA_Color, G_str_to_color() | Platform: All
      Cpu: All |
in trunk the RGBA_Color struct has been moved into include/raster.h. As
its use is more general than just raster maps (e.g. d.graph and D_symbol()
use it) IMO there's no reason for it to be there and it should be moved
into include/colors.h or back into gis.h.
Also, any objections to changing G_str_to_color() in trunk to use
`unsigned char` instead of `int` for R,G,B? It would save some casting.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/969&gt;
Reporter: hamish | Owner: grass-dev@…
      Cpu: All |
Comment(by martinl):
`include/colors.h` sounds as reasonable please for `RGBA_Color` structure.
Please go ahead.
Ticket URL: <http://trac.osgeo.org/grass/ticket/969#comment:1&gt;
      Cpu: All |
Comment(by neteler):
Would this count as an API change? Then make it a blocker or change to
GRASS GIS 8 target.
Ticket URL: <http://trac.osgeo.org/grass/ticket/969#comment:2&gt;
Priority: blocker | Milestone: 7.0.0
      Cpu: All |
Changes (by wenzeslaus):
  * priority: normal => blocker
Comment:
Replying to [comment:2 neteler]:
GRASS GIS 8 target.
It is an API change.
Should we also change `G_str_to_color()`? This would be a blocker too.
Ticket URL: <http://trac.osgeo.org/grass/ticket/969#comment:3&gt;
      Cpu: All |
Replying to [comment:3 wenzeslaus]:
GRASS GIS 8 target.
does anyone planning to work on this issue?
Ticket URL: <http://trac.osgeo.org/grass/ticket/969#comment:4&gt;
      Cpu: All |
Comment(by mmetz):
GRASS GIS 8 target.
RGBA_Color moved to include/display.h in r62002,3 (it is only used in
display functions).
IMHO no, because there is no bug reported for `G_str_to_color()`, using
`unsigned char` instead of `int` means that a range check can no longer be
done, and changing `G_str_to_color()` implies changing
display/d.barscale/draw_scale.c
display/d.extract/main.c
display/d.graph/do_graph.c
display/d.graph/main.c
display/d.grid/fiducial.c
display/d.labels/color.c
display/d.northarrow/draw_n_arrow.c
display/d.path/main.c
display/d.rast/display.c
display/d.thematic.area/main.c
display/d.thematic.area/plot1.c
display/d.vect.chart/main.c
display/d.vect/opt.c
display/d.vect/shape.c
general/g.cairocomp/main.c
general/g.pnmcomp/main.c
lib/cairodriver/Graph.c
lib/display/tran_colr.c
lib/imagery/iclass_signatures.c
lib/imagery/iclass_statistics.c
lib/nviz/nviz.c
lib/ogsf/Gp3.c
lib/ogsf/Gv3.c
lib/pngdriver/Graph_set.c
lib/raster/color_hist.c
misc/m.nviz.image/main.c
ps/ps.map/do_labels.c
ps/ps.map/getgrid.c
ps/ps.map/ps_outline.c
ps/ps.map/ps_vareas.c
ps/ps.map/ps_vlines.c
ps/ps.map/ps_vpoints.c
ps/ps.map/r_border.c
ps/ps.map/r_colortable.c
ps/ps.map/r_header.c
ps/ps.map/r_info.c
ps/ps.map/r_instructions.c
ps/ps.map/r_plt.c
ps/ps.map/r_text.c
ps/ps.map/r_vareas.c
ps/ps.map/r_vlegend.c
ps/ps.map/r_vlines.c
ps/ps.map/r_vpoints.c
ps/ps.map/r_wind.c
raster/r.out.png/main.c
raster/r.out.tiff/main.c
vector/v.colors/read_rgb.c
vector/v.to.rast/support.c
Thus the benefit of changing a harmless type cast comes at a cost.
Ticket URL: <https://trac.osgeo.org/grass/ticket/969#comment:5&gt;
      Cpu: All |
Is anything missing here?
Ticket URL: <http://trac.osgeo.org/grass/ticket/969#comment:6&gt;
Keywords: needinfo, RGBA_Color, G_str_to_color() | Platform: All
      Cpu: All |
Changes (by neteler):
  * keywords: RGBA_Color, G_str_to_color() => needinfo, RGBA_Color,
               G_str_to_color()
Ticket URL: <http://trac.osgeo.org/grass/ticket/969#comment:7&gt;
      Cpu: All |
what is status of this ticket?
Ticket URL: <http://trac.osgeo.org/grass/ticket/969#comment:8&gt;
      Cpu: All |
Replying to [comment:5 mmetz]:
it sounds like something for G8 and not G7 (we are in beta stage)...
Ticket URL: <http://trac.osgeo.org/grass/ticket/969#comment:9&gt;
Priority: blocker | Milestone: 8.0.0
      Cpu: All |
Changes (by martinl):
  * milestone: 7.0.0 => 8.0.0
Comment:
Replying to [comment:9 martinl]:
too.
using `unsigned char` instead of `int` means that a range check can no
longer be done, and changing `G_str_to_color()` implies changing
I took liberty to change milestone of this ticket...
Ticket URL: <http://trac.osgeo.org/grass/ticket/969#comment:10&gt;
