[GRASS-dev] [GRASS GIS] #989: wx georectify: implement best features of i.points
Reporter: hamish | Owner: grass-dev@lists.osgeo.org
Priority: normal | Milestone: 6.5.0
Component: wxGUI | Version: svn-develbranch6
Keywords: georectify i.rectify | Platform: All
      Cpu: All |
wishes from #728:
     * would it be possible to change the color of GCP lines which are 1
standard dev. out from the mean GCP error as orange and 2 S.D. out as red?
that is a nice way in i.points to see where your typos are. Or failing
that, allow sort rows by clicking on column so you could group the worst
offenders to the top.
     * is it possible to bind the arrow keys to move the currently selected
GCP 1 pixel on the map display window?
     * more i.points goodness: can you change the color of the map marker
to orange if that is the currently selected GCP data row? and have it
still display on the map but turn to red if it the Use box is unticked?
     * long shot wish: i.vpoints lets you select a vector map from the
target mapset to overlay on the fly based on the current tansform
calculation. The other nice thing it has is left and right panels, in the
left one you click on a feature in the source image, and in the right you
click on what you know to be the same point in another map (rast or vect)
in the target location. It then uses the x,y from the left pane and the
east,north from the right pane to create the GCP without having to know or
type any coords.
     * from there is the grass5 addon magic auto GCP image tool, but one
(or 5) things at a time :slight_smile:
thanks, Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/989&gt;
Resolution: | Keywords: georectify i.rectify
  Platform: All | Cpu: All
Comment (by hamish):
* it would be nice if there is only one raster map in the group if it was
automatically selected; like is done if there is only one group in the
mapset.
Ticket URL: <https://trac.osgeo.org/grass/ticket/989#comment:1&gt;
* the tool needs a help page.
Ticket URL: <https://trac.osgeo.org/grass/ticket/989#comment:2&gt;
* it would be nice if it asked you "are you sure?" on exit:
  `[Save and exit] / [Abandon changes and exit] / [Cancel]`
very easy to lose half an hour's work by clicking the wrong button & no
safety net.
Hamish
Ticket URL: <https://trac.osgeo.org/grass/ticket/989#comment:3&gt;
Reporter: hamish | Owner: grass-dev@…
      Cpu: All |
Comment(by mmetz):
I am finfished with a wxGUI version of i.points, based on the
georectifier. Some comments on the suggestions:
Replying to [ticket:989 hamish]:
> wishes from #728:
User can define factor for highlight threshold = mean + stddev * factor,
alternatively only the point with the highest RMS error is highlighted.
Additionally, columns can be sorted by clicking on the column head, works
with all columns. First click sorts ascending, second click on same column
head sorts descending.
New coloring: separate colors for regular points, points with high RMS
error, unused points, the currently selected point. Display of unused
points can be disabled.
calculation.
Not sure how easy this is to do in the wxGUI, or more precisely, how to do
this in the wxGUI.
> The other nice thing it has is left and right panels, in the left one
you click on a feature in the source image, and in the right you click on
what you know to be the same point in another map (rast or vect) in the
type any coords.
The left and right panels are now there. Clicking on source or target
display already creates GCP coordinates in the Georectifier, also in the
new GCP Manager. I have put in a third panel with the points list which is
in the same frame on top of the source and target map display. The points
list can be grabbed and dragged outside if desired (floating pane).
New feature: you can adjust the target display to the current zoom of the
source display and vice versa through the toolbar (Adjust display zoom),
works once there are at least 3 halfway accurate GCPs.
Replying to [comment:2 hamish]:
Now there for the new GCP mananger, plus a help button in the toolbar.
Replying to [comment:3 hamish]:
safety net.
Done. Additional safety features are a confirmation message when setting
GCP coords by clicking on a display (can happen accidentially), and a
master copy of the POINTS file which is only updated if the user saves the
points. I thought it necessary because points are saved to the POINTS file
every time RMS is calculated, and I wanted a master copy as backup.
`[Abandon changes and exit]` will overwrite the current POINTS file with
the master copy, `[Save and exit]` will save the GCP list as you see it to
the POINTS file.
Markus M
Ticket URL: <http://trac.osgeo.org/grass/ticket/989#comment:4&gt;
      Cpu: All |
Comment(by neteler):
Sidenote: this enhancement ticket #142 may be of interest, too.
Ticket URL: <http://trac.osgeo.org/grass/ticket/989#comment:5&gt;
      Cpu: All |
Replying to [comment:4 mmetz]:
georectifier.
The tool is very nice and appears to work smoothly.
calculation.
do this in the wxGUI.
While geocoding a scanned historic map, I came across the same problem: It
would be a great help to also display vector map(s) from the target
location.
Ticket URL: <http://trac.osgeo.org/grass/ticket/989#comment:6&gt;
