[GRASS-dev] [GRASS GIS] #99: r.resamp.interp fails for bicubic and bilinear interpolation
Reporter: cmbarton | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: critical | Milestone: 6.3.0
Component: default | Version: unspecified
Keywords: |
I just found out that r.resamp.interp fails for both bicubic and bilinear
interpolation. It makes maps with all NAN values. I used the new NC data
set and produced a set of random elevation points (raster and vector),
then tried to use these in r.resamp.interp. The nearest neighbor routine
worked, but the others did not. I tried the original raster point map and
also tried one that I converted to a CELL map. Neither gave usable
results. FWIW, I got the same result using r.bilinear.
I'm having a very difficult time putting together a class on interpolation
using GRASS today. v.surf.bspline does not work, 2 of the 3 methods in
r.resamp.interp do not work. r.bilinear does not work. Pretty bad press.
Michael
Ticket URL: <http://trac.osgeo.org/grass/ticket/99&gt;
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/
      Type: defect | Status: closed
Resolution: duplicate | Keywords:
Changes (by martinl):
  * status: new => closed
  * resolution: => duplicate
Comment:
Duplicated ticket, see #98.
Ticket URL: <http://trac.osgeo.org/grass/ticket/99#comment:1&gt;
Keywords: |
Michael - unless you have at least on point per cell NAN is actually a correct result.
r.resamp.interp is for resampling a raster map not for interpolating from randomly distributed points.
Eg this is the example from the book - you go from 30m resolution to 10m resolution -
let me know if that does not work (then we are in trouble because this worked so we may have a bug introduced somewhere).
g.region rast=elevation -p
r.resamp.interp elev_ned_30m out=elev_ned10m_bil meth=bilinear
r.resamp.interp elev_ned_30m out=elev_ned10m_bic meth=bicubic
Helena
Michael
GRASS Geographic Information System (GRASS GIS) - http://grass.osgeo.org/_______________________________________________
grass-dev mailing list
