#993: gem fails to compile on ubuntu 9.1
Reporter: mlechner | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Component: default | Version: unspecified
Keywords: gem compile | Platform: Linux
Cpu: Unspecified |
gem fails to compile (ubuntu 9.1):
[[BR]]
user@comp:/svn/grass/trunk/gem$ make
gcc -g -O2 -I/svn/grass/trunk/dist.i686-pc-linux-gnu/include
-I/svn/grass/trunk/dist.i686-pc-linux-gnu/include -D_FILE_OFFSET_BITS=64
-DPACKAGE=\"\" -I/svn/grass/trunk/dist.i686-pc-linux-gnu/include
-I/svn/grass/trunk/dist.i686-pc-linux-gnu/include -o OBJ.i686-pc-linux-
gnu/actions.o -c actions.c
actions.c: In function ‘check_extension’:
actions.c:51: warning: ignoring return value of ‘fscanf’, declared with
attribute warn_unused_result
actions.c:79: warning: ignoring return value of ‘chdir’, declared with
actions.c: In function ‘unpack_extension’:
actions.c:99: warning: ignoring return value of ‘mkstemp’, declared with
actions.c: In function ‘query_extension’:
actions.c:233: warning: ignoring return value of ‘system’, declared with
actions.c: In function ‘source_clean’:
actions.c:943: warning: ignoring return value of ‘system’, declared with
actions.c: In function ‘run_post’:
actions.c:1095: warning: ignoring return value of ‘getcwd’, declared with
In file included from /usr/include/fcntl.h:217,
from actions.c:26:
In function ‘open’,
inlined from ‘unpack_extension’ at actions.c:100:
/usr/include/bits/fcntl2.h:51: error: call to ‘__open_missing_mode’
declared with attribute error: open with O_CREAT in second argument needs
3 arguments
make: *** [OBJ.i686-pc-linux-gnu/actions.o] Fehler 1
Priority: normal | Milestone: 6.4.0
Component: Compiling | Version: svn-trunk
Resolution: | Keywords: gem
Platform: Linux | Cpu: Unspecified
Changes (by neteler):
* milestone: 7.0.0 => 6.4.0
Comment:
Replying to [comment:2 martinl]:
> BTW, couldn't be gem replaced by improved {{{g.extension}}} in trunk?
Martin
Yes, please (also) substitute {{{g.extension}}} shell script in 6.4 with
{{{g.extension}}} Python
script from trunk. The shell script approach isn't really working, so it
is
essentially a bugfix. A semi-broken {{{g.extension}}} in 6.4 does not help
anyone.
Comment (by mlennert):
Replying to [comment:4 neteler]:
Martin
is
help anyone.
> Additionally, it is way easier to use than GEM.
In principle I agree, except for #620. This still needs to be solved.
Comment (by glynn):
Replying to [ticket:993 mlechner]:
from actions.c:26:
In function ‘open’,
3 arguments
Fixed in trunk with r41376.
