[GRASS-dev] [GRASS GIS] #995: WxGUI startup screen fails if GISDBASE path contains non-latin characters
Reporter: marisn | Owner: martinl
     Type: defect | Status: assigned
Priority: critical | Milestone: 7.0.0
Component: wxGUI | Version: svn-releasebranch64
Keywords: wingrass, i18n | Platform: MSWindows Vista
      Cpu: Unspecified |
Comment(by mlennert):
Replying to [comment:19 mlennert]:
> Any news on this issue, at least for GRASS 7 ?
I've just tested in WinXP and can reproduce the startup error when the
path to GISDBASE contains special characters (in this case latin1
accents).
If I follow Maris' comment:18 then the only solution would be to call
grass.py directly from a python script, and not from a .bat. Is that
correct ?
Ticket URL: <http://trac.osgeo.org/grass/ticket/995#comment:20&gt;
      Cpu: Unspecified |
Comment(by marisn):
Replying to [comment:20 mlennert]:
correct ?
I just tested GRASS 7 on Vista. It seems to pass the "welcome" screen just
fine, still CLI (CMD) is not set up correctly (LOCATION_NAME not set).
g.gui starts fine, still it is not possible to import any data as vector
import wizard fails to see any layers in a shapefile and raster data
importing fails when calling r.in.gdal with "file doesn't exist" error.
Exiting from CMD also fails with "Failed to start shell 'C:\Program
Files\GRASS GIS 7.0.svn\msys\bin\sh.exe'".
My guess - elimination of CMD part on windows as per #1891 AND elimination
of touching shell in ANY way is the only solution to fix this issue.
Ticket URL: <http://trac.osgeo.org/grass/ticket/995#comment:21&gt;
      Cpu: Unspecified |
Comment(by martinl):
Replying to [comment:21 marisn]:
just fine, still CLI (CMD) is not set up correctly (LOCATION_NAME not
set). g.gui starts fine, still it is not possible to import any data as
vector import wizard fails to see any layers in a shapefile and raster
data importing fails when calling r.in.gdal with "file doesn't exist"
error. Exiting from CMD also fails with "Failed to start shell 'C:\Program
elimination of touching shell in ANY way is the only solution to fix this
issue.
please could you do the test again with most recent GRASS 7.0 version?
Ticket URL: <http://trac.osgeo.org/grass/ticket/995#comment:22&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: wingrass, i18n
  Platform: MSWindows Vista | Cpu: Unspecified
Changes (by marisn):
  * status: assigned => closed
  * resolution: => fixed
Comment:
Replying to [comment:22 martinl]:
Yes, startup screen now works fine. Still it has just uncovered next set
of problems. As this issue is fixed, I am closing it and will open new
ones for other failures.
Ticket URL: <http://trac.osgeo.org/grass/ticket/995#comment:23&gt;
