#997: g.proj returns wrong datumtrans
Reporter: martinl | Owner: grass-dev@lists.osgeo.org
Type: defect | Status: new
Priority: blocker | Milestone: 6.4.0
Component: Projections/Datums | Version: svn-releasebranch64
Keywords: g.proj | Platform: Unspecified
Cpu: Unspecified |
{{{g.proj}}} behaves strangely when printing datum transform paramaters.
E.g.
g.proj epsg=3004 datumtrans=-1
nothing is printed out even epgs code is given.
Setting datumtrans also doesn't work, e.g.
g.proj epsg=3004 datumtrans=1 -j
+towgs84=-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68
same with
g.proj epsg=3004 datumtrans=2 -j
Everything is working with {{{-t}}} flag, e.g.
g.proj epsg=3004 datumtrans=-1 -t
1
Used in whole rome40 region
towgs84=-225.000,-65.000,9.000
Default 3-Parameter Transformation (May not be optimum for older datums;
use this only if no more appropriate options are available.)
2
Used in Italy (Peninsular Part)
Accuracy 3-4m
3
Used in Italy (Sardinia)
towgs84=-168.6,-34.0,38.6,-0.374,-0.679,-1.379,-9.48
Accuracy 3-4m
4
Used in Italy (Sicily)
towgs84=-50.2,-50.4,84.8,-0.690,-2.012,0.459,-28.08
Accuracy 3-4m
Ticket URL: <http://trac.osgeo.org/grass/ticket/997>
