Hi All,
Current wxGUI code is not in an API form. Its like an application written on python, GRASS GIS and wxPython. This make things worse for people who want to have a simple code which displays a raster/vector data.
First wxGUI should be library and g.gui works as an application of wxGUI library.
If there is a gui library for GRASS, user doesnt need to copy code from existing gui code and sometimes there are problems with SingleBigDisplay and usage of self.parent.window.X.
A lot of refractoring has been done by Anna and Vaclav (GRASSInterface).
I would like to propose some more classes for wxGUI[1]
here is simple demo:
GMFrame ‘connected to’
LayerManagerFrame ‘contains’
LayerManager (non-gui object) ‘contains’
Map (non-gui object) ‘contains’
LayerList (non-gui object) ‘contains’
Layer(s) (Raster/Vector)
comments and suggestions welcome
[1] https://trac.osgeo.org/grass/wiki/wxGUIDevelopment/Refactoring/wxGUIAPIproposal
[2] https://trac.osgeo.org/grass/wiki/wxGUIDevelopment/MapRendering
Rashad
