[GRASS-dev] GRASS GIS Map Display
First, keep in mind that GRASS is a GIS, not a graphics program. So you can't just "display" any graphics file. That is not the purpose of GRASS software.
You can visualize a graphics file in the GRASS GIS environment by importing it into an XY location--i.e., where pixel coordinates are not tied to an earth coordinate system.
If you want to orient a map that comes in a graphic file format (e.g., a scanned map) so that it can be used in a GIS, you will need to georeference it so that each pixel is mapped to a corresponding earth coordinate system. You can use the georeferencing wizard in GRASS to do this.
If you want to display a photo of a place on top of a map, GRASS does not do that. You can save a map to a graphics file and then create your photo/map collage in a program like GIMP or Inkscape.
Michael
____________________
C. Michael Barton
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Aug 12, 2011, at 9:00 AM, <grass-dev-request@lists.osgeo.org> <grass-dev-request@lists.osgeo.org> wrote:
Date: Thu, 11 Aug 2011 18:55:45 +0530
Subject: [GRASS-dev] GRASS GIS Map Display
To: GRASS-dev <grass-dev@lists.osgeo.org>
Message-ID:
  <CA+an3RkNANW9ANd8BHk1=DHhqg+ES2Q9ckU9eLUSwR53NyPr0A@mail.gmail.com>
Content-Type: text/plain; charset="iso-8859-1"
I want to display an image in GRASS GIS Map Display. I have a PNG file which
I want to display. How should I go about that , if some one has suggestion
for this .
thanks
sudeep
Thank you Michael. The PNG file which I want to display is actually a WMS getmap requests response. Now once I have this reponse from WMS, I want this image returned to be displyed as a layer in GRASS GIS Map Display.
Sudeep
On Thu, Aug 11, 2011 at 11:35 PM, Michael Barton <michael.barton@asu.edu> wrote:
First, keep in mind that GRASS is a GIS, not a graphics program. So you can’t just “display” any graphics file. That is not the purpose of GRASS software.
You can visualize a graphics file in the GRASS GIS environment by importing it into an XY location–i.e., where pixel coordinates are not tied to an earth coordinate system.
Michael
C. Michael Barton
Message-ID:
Content-Type: text/plain; charset=“iso-8859-1”
for this .
thanks
sudeep
2011/8/12 Sudeep Singh <sudeep495@gmail.com>:
Could you return a geotiff instead a png?
Sudeep
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
Not always, depends on WMS service. Without geotiff any other way to display it ? like i think d.rast does ?
On Fri, Aug 12, 2011 at 12:39 PM, Luca Delucchi <lucadeluge@gmail.com> wrote:
Sudeep
ciao
Luca
www.lucadelu.org
You can view a PNG in most graphic viewers. Probably it will come up in something if you double click it on almost any desktop platform.
d.rast is for displaying GRASS raster files within the GRASS GIS environment. You would need to import the PNG and convert it to a GRASS raster format to display in GRASS. Unless there is some kind of geocoded version of PNG’s (I don’t know of any), the PNG would not be georeferenced and hence not useable in any way for the GIS without some kind of transformation. Nothing would overlay it correctly. This is one of the very important differences between GIS and a graphics program.
Michael
C. Michael Barton
Tempe, AZ 85287-2402
USA
fax: 480-965-7671(SHESC), 480-727-0709 (CSDC)
www: http://csdc.asu.edu, http://shesc.asu.edu
Sudeep
ciao
Luca
www.lucadelu.org
I suggest you to see wms_request.py [0] (specially GetTiles() and
__set_options() functions)
[0] http://trac.osgeo.org/grass/browser/grass/trunk/scripts/r.in.wms/wms_request.py
ciao
Luca
www.lucadelu.org
Thanks Rashad, Michael and Luca for the suggestions. I am trying with it, if something works out I will post it back. Also Maris suggested to use GRASS_PNG and GRASS_PNGFILE , I am looking into that also. If someone has worked before with GRASS_PNG , please let me know.
thanks
sudeep
On Sat, Aug 13, 2011 at 12:21 PM, Luca Delucchi <lucadeluge@gmail.com> wrote:
ciao
Luca
www.lucadelu.org
The GRASS PNG driver (e.g., GRASS_PNGFILE) controls GRASS display **output**, not input. There is no problem importing a png into GRASS. But you cannot display a png usefully in a GIS unless it is georeferenced.
Maybe I don't understand your request, but it sounds like you don't understand the difference between a georeferenced, geospatial data file and a graphics image file. This is a fundamental concept for raster GIS.
Michael Barton
School of Human Evolution &Social Change
...Sent from my iPad
On Aug 13, 2011, at 4:00 AM, "Sudeep Singh" <sudeep495@gmail.com<mailto:sudeep495@gmail.com>> wrote:
thanks
sudeep
On Sat, Aug 13, 2011 at 12:21 PM, Luca Delucchi <<mailto:lucadeluge@gmail.com>lucadeluge@gmail.com<mailto:lucadeluge@gmail.com>> wrote:
2011/8/12 Sudeep Singh <<mailto:sudeep495@gmail.com>sudeep495@gmail.com<mailto:sudeep495@gmail.com>>:
[0] <http://trac.osgeo.org/grass/browser/grass/trunk/scripts/r.in.wms/wms_request.py&gt; http://trac.osgeo.org/grass/browser/grass/trunk/scripts/r.in.wms/wms_request.py
ciao
Luca
<http://gis.cri.fmach.it/delucchi/&gt;http://gis.cri.fmach.it/delucchi/
<http://www.lucadelu.org>www.lucadelu.org<http://www.lucadelu.org>
