[GRASS-dev] GRASS GIS nightly builds
Doug wrote:
Compiled with openmp and liblas?
fwiw I would not really recommend to compile with OpenMP support
unless you are willing to help develop that. Most of it is fine I
think, but the LU parts used by v.surf.rst and v.surf.bspline are
not very efficient, overhead is like 70%. So you do get a little speedup verus single core, but use a lot of power to do it.
(currently that spawns 10s of thousands of threads when it would be better to spawn nearer to the number of local CPU cores)
For that matter I would not recommend that new users be
encouraged to use development versions at all, unless they are
willing to help develop it, or at least debug it. And if
development nightly builds are made available, it should be made
very clear that it could eat all your data, harm your dog, etc.
best,
Hamish
Hamish,
I’ve been playing with generating surfaces at home on an 8 core AMD vishera system 3.5 ghz Ubuntu 12.04 system with G7 using this point layer:
| Mapset: PERMANENT |
| Database: /data2/grass70_data |
| Title: |
| Map scale: 1:1 |
| Name of creator: dnewcomb |
| Organization: |
| Source date: Sat Feb 23 08:16:54 2013 |
Timestamp (first layer): none
Map format: native
Type of map: vector (level: 1)
Number of points: 73232338 Number of centroids: 0
Number of lines: 0 Number of boundaries: 0
Number of areas: 0 Number of islands: 0
Number of faces: 0 Number of kernels: 0
Number of volumes: 0 Number of holes: 0
Map is 3D: Yes
Number of dblinks: 0
Projection: Lambert Conformal Conic
N: 694901.76 S: 482704.72
E: 580721.99 W: 492486.01
B: 1083.51 T: 5558.44
Digitization threshold: 0
Comment:
(Sat Feb 23 09:49:39 2013) Command finished (34 sec)
I get the following 20ft resolution surface using v.usrf.bspline
r.info map=nc_2_bspline_cubic@PERMANENT
| Layer: nc_2_bspline_cubic@PERMANENT Date: Sat Feb 23 19:13:29 2013 |
| Mapset: PERMANENT Login of Creator: dnewcomb |
| DataBase: /data2/grass70_data |
| Title: bicubic interpolation with Tykhonov regularization ( nc_2_bsplin |
Timestamp: none
Type of Map: raster Number of Categories: 0
Data Type: DCELL
Rows: 10568
Columns: 4412
Total Cells: 46626016
N: 693610 S: 482260 Res: 19.99905375
E: 580722 W: 492486 Res: 19.99909338
Range of data: min = 92.2649807704968 max = 5558.35850509857
Data Description:
generated by v.surf.bspline
Comments:
v.surf.bspline -z input=“nc_2a@PERMANENT” layer=“1” raster_output="n\
c_2_bspline_cubic" sie=40.0 sin=40.0 method=“bicubic” lambda_i=0.01 \
solver=“cholesky” maxit=200 error=0.000001 memory=3000
(Sun Feb 24 19:53:17 2013) Command finished (0 sec)
subregion 920 of 920…
v.surf.bspline complete.
(Sun Feb 24 08:39:12 2013) Command finished (805 min 43 sec)
As you can see , the surface generation ran in 805 minutes. I’m currently rerunning the analysis with maxit = 100 to see how long it takes with the iterations lowered.
Now with v.surf.rst, I generated the following grid:
| Layer: nc_2_rst_npmin_120@PERMANENT Date: Sat Feb 23 01:14:43 2013 |
| Title: ( nc_2_rst_npmin_120 ) |
Timestamp: none
Data Type: FCELL
Rows: 10568
Columns: 4412
Range of data: min = -1.409014e+28 max = 7.890661e+27
Data Source:
vector map nc_2@PERMANENT
Data Description:
generated by v.surf.rst
Comments:
tension=40.000000, smoothing=0.100000
dnorm=215.219236, dmin=9.999527, zmult=1.000000
segmax=40, npmin=120, rmsdevi=29786443112213122633433088.000000
zmin_data=1083.510000, zmax_data=9999.000000
zmin_int=-14090138501368785958609092608.000000, zmax_int=78906611338755
v.surf.rst input=“nc_2@PERMANENT” layer=“1” elevation="nc_2_rst_npmi\
n_120" tension=40. segmax=40 npmin=120 dmin=9.999527 dmax=49.997634 \
zmult=1.0
(Sat Feb 23 08:10:21 2013) Command finished (0 sec)
v.surf.rst complete.
(Sat Feb 23 17:29:55 2013) Command finished (458 min 33 sec)
As you can see, it took only 458 minutes to generate the same resolution surface from the same input points. On the 8 core system, it is using 650% of the cpu to process the data, bouncing up and down 30% or so as it processes.
v.surf.bspline, on the other hand parses the data up into zones and uses 100% cpu up to the time it writes the individual zone out. When it writes the zone out, it spikes up to 750% cpu. For this vector set and grid extent, it generated 920 zones.
V.surf.rst seems to use much more memory than v.surf.bspline
I am of course, speaking as an end user who has not looked at the source code. ( I’m trying to back myself into learning C :-))
Agreed , and I plan on giving the output to other folks to check against the official state grid and the QA points. If this is inefficient, I would really like to try it out after it was made more efficient :slight_smile: Thanks for all the work!
Doug
best,
Hamish
Doug Newcomb
USFWS
Raleigh, NC
919-856-4520 ext. 14 doug_newcomb@fws.gov
The opinions I express are my own and are not representative of the official policy of the U.S.Fish and Wildlife Service or Dept. of the Interior. Life is too short for undocumented, proprietary data formats.
On Mon, Feb 25, 2013 at 2:49 AM, Newcomb, Doug <doug_newcomb@fws.gov> wrote:
I've been playing with generating surfaces at home on an 8 core AMD vishera
Your point layer extents:
bspline surface:
Note the range of data, compare to the original points and the rst surface.
As you can see , the surface generation ran in 805 minutes. I'm currently
iterations lowered.
It will make no difference because you used the cholesky solver. The
module could be faster if you recompile GRASS without openmp, or use a
system with at least 16 cores. v.surf.bspline would be much faster if
you increase the spline steps to 60 or 80.
rst surface:
Note the range of data. Looks like serious overshoots. You could try
different values for tension and smoothing for a smaller subregion in
order to get a range of data that is closer to the original data.
processes.
See above, recompile GRASS --without-openmp to get more speed.
v.surf.bspline has a memory option (defualt 300MB). But giving
v.surf.bspline more memory will not make processing faster, most of
the time is spent in the solver.
Markus M
code. ( I'm trying to back myself into learning C :-))
Very useful testing report!
Markus M
