when installing incomplete GRASS GIS 6.4.3 from packages on Ubuntu I get the following error when I start using grass
command:
Starting GRASS …
python: can’t open file ‘/usr/lib/grass64/etc/wxpython/gis_set.py’: [Errno 2] No such file or directory
Received EXIT message from GUI.
GRASS is not started. Bye.
It is caused by the fact that I have installed grass-core and not grass-gui, so I have modules and grass
command but I don’t have any GUI.
Although, packaging is what caused the problem, it seems that it is our problem since we claim that GRASS is usable without GUI or don’t we?
Once user reads grass -h
he or she can realize that grass -text
could start and it of course starts. The problem is that when grass-gui package is not available, text interface should start (should be the default or fallback), but once grass-gui is installed GUI should be the default option.
Besides the start, modules do not have their GUIs:
g.region --ui
python: can’t open file ‘/usr/lib/grass64/etc/wxpython/gui_core/forms.py’: [Errno 2] No such file or directory
This is not so critical error, just a better error message would be nice. Maybe, the better error message would be enough also at start up. Something, like “Have you installed GRASS GIS with GUI?”
I haven’t checked the source code but I guess that it is the same for all versions including trunk.
Vaclav
Hi Vaclav,
I had made some changes in control script to fix this behaviour some time ago. Could tell which version of Ubuntu you are using and thee ppa. FYI, I had updated only grass-ppa[1] not in the ubuntugis
[1] https://launchpad.net/~grass/+archive/grass-stable
On Wed, Jan 1, 2014 at 10:47 PM, Vaclav Petras <wenzeslaus@gmail.com> wrote:
command:
Starting GRASS …
g.region --ui
Vaclav
grass-dev mailing list
grass-dev@lists.osgeo.org
Rashad
I used only the standard Ubuntu repository, Ubuntu 13.10, no ubuntugis, no grass-ppa.
Just to understand, what change have you done? Can the change be viewed somewhere? Do you think that it should be fixed while packaging and not in GRASS (e.g., because it is hard to tell if it is a real error or just missing package)?
Vaclav
On Thu, Jan 2, 2014 at 3:09 AM, Rashad M <mohammedrashadkm@gmail.com> wrote:
Hi Vaclav,
command:
Starting GRASS …
g.region --ui
Vaclav
Rashad
Hi vaclav,
here is the control file[1]. I think this should be fixed in packaging. grass virtual package includes grass-gui package. Failure in building grass-gui probably “xml or version key error” may result in the above behavious. In that case a patch can be applied when building deb file so that if wxpython dir is not found it can show a better error message. One thing can be fixed is checking the error message from parsing like i said above keyErorr[‘version’]. There is a better complete error message a while ago in grass-dev list.
[1] http://bazaar.launchpad.net/~grass/grass/grass64_release_debian/view/head:/control
On Thu, Jan 2, 2014 at 3:49 PM, Vaclav Petras <wenzeslaus@gmail.com> wrote:
Rashad
Vaclav
Hi Vaclav,
command:
Starting GRASS …
g.region --ui
Vaclav
Rashad
Hi Vaclav,
This seems to be the thread.
http://osgeo-org.1560.x6.nabble.com/grass70-problem-with-gui-td5093509.html
As per Martin’s suggestion if this error is tracked in error.log then atleast we know the grass-gui is broken.
On Thu, Jan 2, 2014 at 9:42 PM, Rashad M <mohammedrashadkm@gmail.com> wrote:
Hi vaclav,
Rashad
Rashad
Vaclav
Hi Vaclav,
command:
Starting GRASS …
g.region --ui
Vaclav
Rashad
