[GRASS-dev] GRASS ibiblio mirror stuck in the past
looking to download the latest RC from Ibiblio, I notice the nightly
rsync is broken and it hasn't updated since the 8th of September.
http://grass.ibiblio.org
http://grass.ibiblio.org/grass62/source/
thanks,
Hamish
I made a quick check in our log file:
[neteler@krokus log]$ nslookup grass.ibiblio.org
Server: 217.77.80.3
Address: 217.77.80.3#53
Non-authoritative answer: grass.ibiblio.org canonical name = vhost.ibiblio.org.
Address: 152.46.7.81
grep 152.46.7 /var/log/messages
Oct 24 08:50:03 krokus rsyncd[13711]: name lookup failed for 152.46.7.122: Name or service not known
Oct 24 08:50:03 krokus rsyncd[13711]: rsync denied on module grass from unknown (152.46.7.122)
Apparently the grass.ibliblio.org server changes the IP.
But:
nslookup 152.46.7.122
Server: 217.77.80.3
** server can't find 122.7.46.152.in-addr.arpa: NXDOMAIN
Anyway, I have added 152.46.7.122 to the list of permitted sites.
By tommorrow it should be back in sync.
Thanks for pointing out the problem,
On Tue, Oct 24, 2006 at 03:16:39PM +1300, Hamish wrote:
thanks,
Hamish
Server: 217.77.80.3
                                       grass.ibiblio.org
                                       canonical name =
                                       vhost.ibiblio.org.
152.46.7.122: Name or service not known Oct 24 08:50:03 krokus
(152.46.7.122)
But:
Server: 217.77.80.3
Could the same problem be behind the Aarnet .au mirror being stalled at
Sept 18?
http://mirror.aarnet.edu.au/pub/grass/index.php
Hamish
Hamish wrote on 10/25/2006 05:37 AM:
http://grass.ibiblio.org is back in sync now.
Sept 18?
I don't see any syncronization attempts from there but I have fixed the
IP of mirror.aarnet.edu.au. If it doesn't update within 1-2 days, they
should
check if their rsync cronjob is still running.
