On Thu, Apr 14, 2016 at 9:55 AM, Paulo van Breugel <p.vanbreugel@gmail.com>
wrote:
I would have to go through the individual examples but sometimes it might
be be clear what is a message to inform user about something and what is a
text output of the module. A rule of thumb can be that modules which output
maps, (usually) don't do text output, so they shouldn't use print().
In this case (r.vif) the output is not a map, but a list of values, i.e.,
text output (see below). Based on the guidelines, I would assume I should
use print()?
Then print() is the right thing. I would recommend finding a similar module
and see its behavior. For example, r.univar will give you human readable
report and also parseable output (in this case by
grass.script.parse_command()). Both are written to standard output (the
g.message wrappers use standard error output).
All variables
variable vif sqrtvif
2000_01_precip@climate_1970_2012 2.30 1.52
2000_03_tempmean@climate_1970_2012 24.95 5.00
2000_11_precip@climate_1970_2012 3.54 1.88
2001_02_precip@climate_1970_2012 4.55 2.13
2001_04_tempmean@climate_1970_2012 25.01 5.00
Variable '2001_04_tempmean@climate_1970_2012' removed
2000_03_tempmean@climate_1970_2012 2.19 1.48
2000_11_precip@climate_1970_2012 3.48 1.87
2001_02_precip@climate_1970_2012 4.54 2.13
Final selected variables are: 2000_01_precip, 2000_03_tempmean, 2000_11_precip, 2001_02_precip
with as maximum VIF: 5.69787583189
This definitively looks like something from r.report or r.info.
Perhaps the most important thing is that one should avoid mixing the two,
which is something that maybe could go somewhere in the wiki?
Feel free to extent either wiki or guidelines if you think it is not clear
enough.
I wouldn't mind doing so, but I probably should understand better myself
what exactly the issue is with using both print() and grass.info() in one
script. Based on what I read in the guidelines, I am not clear whether
using both is against the guidelines as such,
You can use both in one script. The difference is what you use them for.
For example, a lot of modules will tell which map was created (this is done
through g.message or its C equivalents), while g.region -p will use
standard output. Some cases are unclear, for example v.in.lidar uses
standard output (fprintf(stdout,...)) to tell how many points imported.
G_message() might be more appropriate here because it is an message to the
user while the output is the vector map. If G_message() would be used, this
output could be silenced by --quiet.
but technically it seems it can cause problems as you explained (and I
experienced).
They are mostly related to syncing of stdout and strerr streams which is
more challenging for the GUI (and may need some fixing there).
