[GRASS-dev] GRASS_INFO_WARNING(5712, 1): Unable to start driver <sqlite>
Hi devs,
with
System Info
GRASS version: 7.1.svn
GRASS SVN revision: 66775
Build date: 2015-11-10
Build platform: i686-pc-mingw32
GDAL: 1.11.3
PROJ.4: 4.8.0
GEOS: 3.5.0
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1
I get:
C:\Users\xxxxx>No such file or directory: Cannot open drivers directory
GRASS_INFO_WARNING(5712,1): Unable to start driver <sqlite>
GRASS_INFO_END(5712,1)
GRASS_INFO_WARNING(5712,2): Unable open database
<C:\grassdata\nc_spm_08_grass7\
PERMANENT\sqlite\sqlite.db> by driver <sqlite>
GRASS_INFO_END(5712,2)
GRASS_INFO_ERROR(5712,3): Unable to start driver <sqlite>
GRASS_INFO_END(5712,3)
it is the NC sample data set.
any idea?
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/GRASS-INFO-WARNING-5712-1-Unable-to-start-driver-sqlite-tp5235582.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
any idea?
Likely related to something with compilation around r66773:
Broken: GRASS-GIS/grass-ci#478 (master - e2f3140)
https://lists.osgeo.org/pipermail/grass-dev/2015-November/077266.html
wenzeslaus wrote
On Tue, Nov 10, 2015 at 2:10 PM, Helmut Kudrnovsky &lt;
hellik@
<sqlite>
any idea?
grass-dev mailing list
grass-dev@.osgeo
yes it seems so:
http://wingrass.fsv.cvut.cz/grass71/logs/log-r66775-116/error.log
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/GRASS-INFO-WARNING-5712-1-Unable-to-start-driver-sqlite-tp5235582p5235674.html
