Hello list,
In the process of tracking down a QGIS bug, I found something unusual with a few grass libraries and commands. Is it normal to have 2 versions of GEOS linked to a grass library or command? I ask because I notice that the following files have GEOS 3.1 and 3.2 linked to them:
/usr/local/grass-6.5.svn/lib/lib.6.5.svn.so
/usr/local/grass-6.5.svn/lib/libgrass_neta.6.5.svn.so
/usr/local/grass-6.5.svn/bin/v.net.bridge
/usr/local/grass-6.5.svn/bin/v.net.flow
/usr/local/grass-6.5.svn/bin/v.net.spanningtree
/usr/local/grass-6.5.svn/bin/v.net.components
/usr/local/grass-6.5.svn/bin/v.net.allpairs
Bob Moskovitz
Research Analyst I
Seismic Hazard Zonation Project
California Geological Survey
http://www.conservation.ca.gov/cgs/shzp
CONFIDENTIALITY NOTICE: This communication is intended only for the use of the individual or entity to which it is addressed. This message contains information from the State of California, California Geological Survey, which may be privileged, confidential and exempt from disclosure under applicable law, including the Electronic Communications Privacy Act. If the reader of this communication is not the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication is strictly prohibited.
