What libraries I need to install in each cluster-node to run grass in a cluster? With SGE or Slurm?
Thanks!
---------------------------- Confidencialidad: Este mensaje y sus ficheros adjuntos se dirige exclusivamente a su destinatario y puede contener información privilegiada o confidencial. Si no es vd. el destinatario indicado, queda notificado de que la utilización, divulgación y/o copia sin autorización está prohibida en virtud de la legislación vigente. Si ha recibido este mensaje por error, le rogamos que nos lo comunique inmediatamente respondiendo al mensaje y proceda a su destrucción. Disclaimer: This message and its attached files is intended exclusively for its recipients and may contain confidential information. If you received this e-mail in error you are hereby notified that any dissemination, copy or disclosure of this communication is strictly prohibited and may be unlawful. In this case, please notify us by a reply and delete this email and its contents immediately. ----------------------------
(attachments)
Fernando Sierra Pajuelo
System Administrator / Researcher
c/ Sola nº 1; 10200 TRUJILLO, SPAIN
Tel: +34 927 65 93 17 Fax: +34 927 32 32 37
On Thu, Oct 11, 2012 at 10:24 AM, Fernando Sierra
<fernando.sierra@ciemat.es> wrote:
What we do on our cluster:
- install GRASS in /usr/local/
- export /usr/local/ via NFS to the blades
- use Grid Engine (SGE), see GRASS Wiki
Like this we have a single installation to maintain which is
visible to all cluster nodes.
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
On 11/10/12 11:39, Markus Neteler wrote:
On Thu, Oct 11, 2012 at 10:24 AM, Fernando Sierra <fernando.sierra@ciemat.es> wrote:
Slurm?
What we do on our cluster: - install GRASS in /usr/local/ - export /usr/local/ via NFS to the
blades - use Grid Engine (SGE), see GRASS Wiki
Like this we have a single installation to maintain which is visible to all cluster nodes.
effectively the same here, only that, as I am only a "normal" cluster user, I installed it GRASS
in my home directory.
Rainer
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://www.enigmail.net/
iEYEARECAAYFAlB2ppUACgkQoYgNqgF2egqMfwCfa4QlfVr+Qkt6kwqf+TSMGxIJ
v3kAmQGQpnYzzKbS4HjD88kz2+yqMtX5
=7Uqu
-----END PGP SIGNATURE-----
Thanks for your help. It works Perfectly.
Rainer
