[GRASS-dev] GRASS manual layout overhaul: less redundancy, more compact
I have modified
  tools/build_html_index.sh
to generate more compact HTML pages, also with less redundancy:
http://grass.osgeo.org/grass64/manuals/html64_user/index.html
(also 6.4.0svn and 7, also validated in http://validator.w3.org/).
Feel free to further fine tune.
Markus wrote:
I have modified
redundancy:
re. r36022, d.font.freetype and d.text.freetype should not be on the
no-G_parser() list. perhaps they are failing to run/build on the server
for some other reason?
here they correctly have name:description in the display modules list
like any other script.
Hamish
On Sun, Feb 22, 2009 at 6:44 AM, Hamish <hamish_b@yahoo.com> wrote:
Markus wrote:
I have modified
Mhh, no idea. They has only the name of the other (new) module
but no description.
Here it fails.
Well, I guess that the addition to the list in tools/build_html_index.sh
is rather harmless (but if you don't think so we can revert that).
Markus wrote:
>> I have modified tools/build_html_index.sh
Hamish:
Markus:
module but no description.
Here it fails.
what does 'd.font.freetype --help' say on that machine?
Does the build use freetype compile flag? are d.font and d.text there?
the scripts are just wrappers that do like:
  exec d.text "$@"
shrug.
anyway, they aren't active; so we shouldn't advertize them; so I've
added them to the ignore list in the script. problem solved :wink:
g.manual still works if anyone is curious.
that script is enough of an ugly PITA to follow without more noise...
Hamish
ps- what's up with r.li.daemon? the html page is on the no-G_parser()
list; the Makefile says it's what becomes libgrass_rli.so, and main.c
is named main.c.unused? former frontend to the library or stand-alone
version?
On Wed, Feb 25, 2009 at 10:47 AM, Hamish <hamish_b@yahoo.com> wrote:
Hamish:
Markus:
Here it fails.
Usage:
d.font [-lL] [font=string] [path=string] [charset=string] [--verbose]
   [--quiet]
yes
yes
exec d.text "$@"
shrug.
Perfect :slight_smile:
Hamish
version?
In the directory libgrass_rli.6.5.svn.so is used. I assume that main.c.unused
serves as a template (maybe better name it as such?).
