[GRASS-dev] grass on osgeo4w and spyder
Hi devs,
Has any of you experience in running Spyder (or any other Python IDE)
from the GRASS command line (GRASS installed on Windows 10 with
OSGeo4W)? Any tips for how to set this up?
I can run R/Rstudio from the GRASS command line. Nothing to set up,
just typing in rstudio on the grass gis command line to fire up
rstudio.
That does not work, however, with Spyder (installed with Anaconda). As
an alternative, I tried to install Spyder with pip on the osgeo4w
command line. Installation seems to work, but when typing in spyder3
on the command line, nothing happens.
Best regards,
Paulo
pvanbosgeo wrote
Hi devs,
rstudio.
have a look at
https://grasswiki.osgeo.org/wiki/Tools_for_Python_programming#PyCharm_IDE
it's related to
add python-grass.bat for Python initialization
https://github.com/OSGeo/grass/pull/436
best regards
Helmut
Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
rstudio.
I've implemented this by integrating
https://github.com/OSGeo/grass/tree/master/mswindows/external/rbatch
and
by adding some lines to the startup environment
https://github.com/OSGeo/grass/blob/master/mswindows/env.bat#L18
best regards
Helmut
On Tue, Mar 24, 2020 at 4:31 PM Helmut Kudrnovsky <hellik@web.de> wrote:
pvanbosgeo wrote
Hi devs,
rstudio.
have a look at
it’s related to
Once you figure out that for Spyder, please consider updating Windows instructions at:
https://grasswiki.osgeo.org/wiki/Tools_for_Python_programming#Spyder_editor
Vaclav
