[GRASS-dev] GRASS on Windows Vista
GRASS 6.4SVN with MSYS is not running on Windows Vista:
Cleaning up temporary files …
Starting GRASS …
UPOZORNĚNÍ: Attention!
UPOZORNĚNÍ: Locking is not supported on Windows!
/ / __ / | / / / / __/ / /
/ / __/ /
/ / /| | _
\ / / __ / / _
/ / , / ___ |
_
// _///_/
Welcome to GRASS 6.4.0svn (2010)
GRASS homepage: http://grass.osgeo.org/
This version running thru: Bourne Shell (/bin/sh)
Help is available with the command: g.manual -i
See the licence terms with: g.version -c
If required, restart the GUI with: g.gui wxpython
When ready to quit enter: exit
GRASS 6.4> Traceback (most recent call last):
File “c:/Program Files/GRASS-64-SVN/etc/wxpython/wxgui.py”, line 1834, in
sys.exit(main())
File “c:/Program Files/GRASS-64-SVN/etc/wxpython/wxgui.py”, line 1827, in main
app = GMApp(workspaceFile)
File “c:/Program Files/GRASS-64-SVN/etc/wxpython/wxgui.py”, line 1752, in init
wx.App.init(self, False)
File “C:\OSGeo4W\apps\Python25\lib\site-packages\wx-2.8-msw-unicode\wx_core.py”, line 7935, in init
self._BootstrapApp()
File “C:\OSGeo4W\apps\Python25\lib\site-packages\wx-2.8-msw-unicode\wx_core.py”, line 7509, in _BootstrapApp
return core.PyApp__BootstrapApp(*args, **kwargs)
File “c:/Program Files/GRASS-64-SVN/etc/wxpython/wxgui.py”, line 1770, in OnInit
workspace = self.workspaceFile)
File “c:/Program Files/GRASS-64-SVN/etc/wxpython/wxgui.py”, line 192, in init
self.NewDisplay(show=False)
File “c:/Program Files/GRASS-64-SVN/etc/wxpython/wxgui.py”, line 1248, in NewDisplay
auimgr=self._auimgr, showMapDisplay=show)
File “C:\Program Files\GRASS-64-SVN\etc\wxpython\gui_modules\wxgui_utils.py”, line 95, in init
self.Map = render.Map() # instance of render.Map to be associated with display
File “C:\Program Files\GRASS-64-SVN\etc\wxpython\gui_modules\render.py”, line 402, in init
self.projinfo = self.ProjInfo()
File “C:\Program Files\GRASS-64-SVN\etc\wxpython\gui_modules\render.py”, line 765, in ProjInfo
p = gcmd.Command([‘g.proj’, ‘-p’])
File “C:\Program Files\GRASS-64-SVN\etc\wxpython\gui_modules\gcmd.py”, line 369, in init
_("Error: ") + self.GetError()))
gui_modules.gcmd.CmdError
GRASS 6.4>
System report: Execution failed:‘g.proj -p’
2010/7/31 Pavel Hnilica <pavel.hnilica@gmail.com>:
Where di you get it (which version)?
_________________________________________________________________________________________________
Cleaning up temporary files ...
Starting GRASS ...
__________ ___ __________ _______________
/ ____/ __ \/ | / ___/ ___/ / ____/ _/ ___/
/ / __/ /_/ / /| | \__ \\_ \ / / __ / / \__ \
/ /_/ / _, _/ ___ |___/ /__/ / / /_/ // / ___/ /
\____/_/ |_/_/ |_/____/____/ \____/___//____/
File "c:/Program Files/GRASS-64-SVN/etc/wxpython/wxgui.py", line 1834, in
<module>
sys.exit(main())
File "c:/Program Files/GRASS-64-SVN/etc/wxpython/wxgui.py", line 1827, in
main
File "c:/Program Files/GRASS-64-SVN/etc/wxpython/wxgui.py", line 1752, in
__init__
wx.App.__init__(self, False)
File
"C:\OSGeo4W\apps\Python25\lib\site-packages\wx-2.8-msw-unicode\wx\_core.py",
line 7935, in __init__
File
return _core_.PyApp__BootstrapApp(*args, **kwargs)
File "c:/Program Files/GRASS-64-SVN/etc/wxpython/wxgui.py", line 1770, in
OnInit
File "c:/Program Files/GRASS-64-SVN/etc/wxpython/wxgui.py", line 192, in
__init__
File "c:/Program Files/GRASS-64-SVN/etc/wxpython/wxgui.py", line 1248, in
NewDisplay
File "C:\Program
Files\GRASS-64-SVN\etc\wxpython\gui_modules\wxgui_utils.py", line 95, in
__init__
with display
File "C:\Program Files\GRASS-64-SVN\etc\wxpython\gui_modules\render.py",
line 402, in __init__
p = gcmd.Command(['g.proj', '-p'])
File "C:\Program Files\GRASS-64-SVN\etc\wxpython\gui_modules\gcmd.py",
line 369, in __init__
GRASS 6.4>
System report: Execution failed:'g.proj -p'
Please try a recent nightly version here:
http://josef.fsv.cvut.cz/wingrass/grass64/
The problem might be already fixed.
This should go to the list,
---------- Forwarded message ----------
Date: 2010/7/31
Subject: Re: [GRASS-dev] GRASS on Windows Vista
To: Markus Neteler <neteler@osgeo.org>
This version:
WinGRASS-6.4.SVN-r42933-1-Setup.exe
http://josef.fsv.cvut.cz/wingrass/grass64/WinGRASS-6.4.SVN-r42933-1-Setup.exe
2010/7/31 Markus Neteler <neteler@osgeo.org>
> Starting GRASS ...
> <module>
> sys.exit(main())
> main
> __init__
> File
> File
> OnInit
> __init__
> NewDisplay
> File "C:\Program
> __init__
> with display
> GRASS 6.4>
p = gcmd\.Command\(\[&#39;g\.proj&#39;, &#39;\-p&#39;\]\)
what says
g.proj -p
if you run the command from MSys command line?
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
Coult this be a variation of http://trac.osgeo.org/grass/ticket/1099 ?
Maris.
2010/7/31, Martin Landa <landa.martin@gmail.com>:
what says
g.proj -p
Martin
grass-dev mailing list
grass-dev@lists.osgeo.org
