[GRASS-dev] GRASS && OpenCV
Mohammed Rashad wrote:
I just started my work but stuck in the intial statement
G__gisinit(char*....)
how does the Makefile look?
are $(GISLIB) and $(GISDEP) present? i.e. does you module's Makefile closely
resemble other similar modules?
if building from outside of the main source tree, do you have MODULE_TOPDIR
pointed to where the source tree is?
maybe add the grass lib dir to your /etc/ld.so.conf file, then as root run
ldconfig. then the grass libs will be in the library search path.
but be careful with that if you have multiple grass versions installed,
if so you might want to export the LD_LIBRARY_PATH= environment variable
at run time to add the lib dir into the library search path temporarily.
Hamish
here is my make command
g++ -I/usr/lib/grass64/include grass.o -L/usr/lib/grass64/lib -lgrass_I -lgrass_Iortho -lgrass_arraystats -lgrass_bitmap -lgrass_btree -lgrass_cairodriver -lgrass_cdhc -lgrass_cluster -lgrass_datetime -lgrass_dbmibase -lgrass_dbmiclient -lgrass_dbmidriver -lgrass_dbstubs -lgrass_dgl -lgrass_dig2 -lgrass_display -lgrass_driver -lgrass_dspf -lgrass_edit -lgrass_form -lgrass_g3d -lgrass_gis -lgrass_gmath -lgrass_gpde -lgrass_gproj -lgrass_interpdata -lgrass_interpfl -lgrass_iostream -lgrass_ismap -lgrass_lidar -lgrass_linkm -lgrass_lrs -lgrass_manage -lgrass_nviz -lgrass_ogsf -lgrass_pngdriver -lgrass_psdriver -lgrass_qtree -lgrass_raster -lgrass_rli -lgrass_rowio -lgrass_rtree -lgrass_segment -lgrass_shape -lgrass_sim -lgrass_sites -lgrass_sqlp -lgrass_stats -lgrass_symb -lgrass_trans -lgrass_vask -lgrass_vect -lgrass_vedit -o wgrass
libgrass_gis is there but still error
/home/rashad/grass.cpp:5: undefined reference to `G__gisinit(char const*, char const*)’
G__gisinit(char*…)
are $(GISLIB) and $(GISDEP) present? i.e. does you module’s Makefile closely
Hamish
Rashad
