On Sun, Dec 18, 2011 at 6:13 PM, Mohammed Rashad
<mohammedrashadkm@gmail.com> wrote:
On Sun, Dec 18, 2011 at 9:13 PM, Martin Landa <landa.martin@gmail.com>
wrote:
2011/12/18 Mohammed Rashad <mohammedrashadkm@gmail.com>:
>> echo /usr/lib/grass64/lib >> /etc/ld.so.conf
>> ldconfig
> Hi Hamish
> I tried that but no luck
well, and are really GRASS libraries installed in `usr/lib/grass64` ?
yes martin. I also installed grass 6.4.2 from source checkout
That was not Martin's question. Martin asked if the GRASS libraries
are really installed in `usr/lib/grass64`. By default, after `make
install`, libraries are installed in `$prefix/grass-6.4.2svn/lib`,
prefix would be `usr/local`on default. Please check again the
directory `$prefix/grass-6.4.2svn/lib`, optionally replacing $prefix
with your choice of prefix.
well, and are really GRASS libraries installed in usr/lib/grass64 ?
That was not Martin’s question. Martin asked if the GRASS libraries
are really installed in usr/lib/grass64. By default, after make install, libraries are installed in $prefix/grass-6.4.2svn/lib,
prefix would be usr/localon default. Please check again the
directory $prefix/grass-6.4.2svn/lib, optionally replacing $prefix
I installed grass from source it is installed on /usr/local/.grass-6.4.2svn
i also installed from lucid repos it is installed on /usr/lib/grass64
so there are two installations. I also tried to link with each sepreately and add one by one to /etc/ld.so.cinbf
and do ldconfig
but still error
As my title indicates there is one more question GRASS && OpenCV. Is there any need for it. If yes please tell me…
