[GRASS-dev] GRASS posters in svn add-on
Hi
These 85 MB in svn-add-on repository seems not to be a nice idea....
maybe separate repository?
Jarek
idea....
I agree. No clear idea about a better home though; keeping in SCM somewhere
seems like a good idea vs. serving directly from download.osgeo.org/grass.
Does bzip2'ing help? If not, maybe split off into a new grass-promo svn
parallel to grass-web and grass-addons?
Hamish
(of limited bandwidth)
2010/4/26 Hamish <hamish_b@yahoo.com>:
idea....
We could just create a new svn directory called "marketing".
Yes (svn mv should be used then, right?).
2010/5/2 Markus Neteler <neteler@osgeo.org>:
idea....
With help of FrankW I have created a new repo "grass-promo":
svn co http://svn.osgeo.org/grass/grass-promo
It will contain:
- grassflyer/
- grassposter/
which I have tried to copy over with "svn copy" which bailed out with an error
message. Also "svn move" is unsupported.
I guess that I am missing the trick.
2010/5/8 Markus Neteler <neteler@osgeo.org>:
It will contain:
- grassflyer/
- grassposter/
done in r42197 & r42198. I would suggest to move from grass-addons to
grass-promo also 'tutorials' and 'screenshots'.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
It will contain:
- grassflyer/
- grassposter/
+1
Marjus:
> bailed out with an error message. Also "svn move" is unsupported.
I used to have the same problem moving from grass-addons to the main
tree on my laptop. Solution was to make sure both had the identical source
URL. in my case the initial SVN checkout for grass-addons was done read-only
http:// instead of https://, so URLs were different. Enough of an "ah-ha"
moment that IIRC I documented the fix on the trac wiki "how to SVN" page.
regards,
Hamish
2010/5/10 Markus Neteler <neteler@osgeo.org>:
+1
done in r42208.
Martin
