(I take liberty to bring this back to the list for the record):
On Sat, May 30, 2015 at 2:04 PM, Vincent Bain <bain@toraval.fr> wrote:
Markus,
here it is :
the attached archive contains a svg inkscape file with several layers
you can switch on/off independantly :
-"bg" : white background ;
-"logo" : grass logo, the historical version I cleaned up ;
-"logo (greyscale)" : the same in gray ;
-"GRASS GIS (modified kerning)" : the capitalized name composed in Fira
Sans Medium and Thin weights, and with optimized kerning ;
-"grass gis" : the lowercase title ;
-"Bringing..." the slogan.
Turning on/off these layers, you can output a variety of png files, the
ones I provided are ripped at 600 dpi.
Hope this is the correct answer to your need,
Bye,
Vincent.
thanks for your efforts!
Finally uploaded to
http://grass.osgeo.org/download/logos/
--> zip file
Thanks again,
Happy to see there is finally a consensual "current logogram".
As I just said to Markus offlist, the svg file was generated with
Inkscape. Needs the following fonts to display correctly
- Fira sans : http://www.fontsquirrel.com/fonts/fira-sans
- EB Garamond : http://www.fontsquirrel.com/fonts/eb-garamond
Ciao,
Vincent.
Le samedi 18 juillet 2015 à 16:13 +0200, Markus Neteler a écrit :
> Markus,
> here it is :
> Bye,
> Vincent.
Finally uploaded to
--> zip file
Thanks again,
