[GRASS-dev] grass.py: vector_db
maybe we could change interfaces of vector_db. Now the function
returns list of the list, e.g.
[['1', 'ar_1', 'cat', 'grass', 'pg'], ['1', 'ar_2', 'cat', 'grass', 'pg']]
I suggest to return a dictionary, e.g.
{ 1 : { 'table' : 'ar_1', 'key': 'cat', 'database': 'grass', 'driver' : 'pg' },
2 : { 'table' : 'ar_2', 'key': 'cat', 'database': 'grass', 'driver' : 'pg' } }
If no objections I will apply this change and update all scripts in g7.
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
Seems reasonable, although I would suggest:
1. Remove the layer parameter from the function; you may as well use:
  fields = grass.vector_db(...)[layer]
if you want a specific layer.
Having the function return different types of data depending upon the
arguments probably wasn't a great design choice. IIRC, I assumed that
'v.connect -g ... layer=...' would work, then realised that it
doesn't, and fixed it inside the function rather than changing the
interface.
2. Keep the layer in the per-layer dictionaries, as well as using the
value as the key for the top-level dictionary, i.e.
{ 1 : { 'layer' : 1, 'table' : 'ar_1', 'key': 'cat', 'database': 'grass', 'driver' : 'pg' },
  2 : { 'layer' : 2, 'table' : 'ar_2', 'key': 'cat', 'database': 'grass', 'driver' : 'pg' } }
If nothing uses it, it's harmless, and it might make life simpler if
you need to use the dictionary outside of the loop (i.e. if you save
the dictionary for later, or pass it to a separate function, you don't
have to record the layer number separately).
2008/12/20 Glynn Clements <glynn@gclements.plus.com>:
interface.
done in r34952. I also added vector_layer_db() for common usage of
vector_db() which calls fatal() with standardized error message.
Martin
