Hello,
To get the Map_info structure we have to wrap also dig_structs.h (so
we must add dig_struct.i to the interfaces dir by adding a line in the
Makefile there).
I also added some lines to the python-swig interface file to provide
access to int/float/double arrays. Find attached the patch to
python_grass.i and below the updates to the script proposed by Markus
that now works with the new Map_info object.
#!/usr/bin/python
import python_grass6 as g6lib
input = 'soils'
mapset = 'PERMANENT'
g6lib.G_gisinit('')
g6lib.Vect_set_open_level (2)
map = g6lib.Map_info()
g6lib.Vect_open_old_head (map, input, mapset)
print 'Vect is 3D: ', g6lib.Vect_is_3d (map)
g6lib.Vect_open_old(map, input, mapset)
print 'Vect DB links: ', g6lib.Vect_get_num_dblinks(map)
g6lib.Vect_close(map)
## end of the python script
Alessandro
2006/9/24, Markus Neteler <neteler@itc.it>:
I have added the Vector API to the GRASS-SWIG-Python interface.
Now w have to figure out how to use it
I am struggling there (don't know much about Python yet):
#### snip #####
input = 'soils'
g6lib.G_gisinit('')
## how to set Map?
g6lib.Vect_open_old_head (Map, input, mapset)
print 'Vect is 3D:'
print g6lib.Vect_is_3d (Map)
g6lib.Vect_open_old(input, mapset)
print 'Vect DB links'
print g6lib.Vect_get_num_dblinks(Map)
g6lib.Vect_close(Map)
#### snap #####
grass-dev mailing list
grass-dev@grass.itc.it
Alessandro Frigeri, PhD
(attachments)
python_grass6.i.patch (449 Bytes)
