[GRASS-dev] grass python problem
Hi Everyone
Hope this email finds you well.
I can run r.cross in console with following command:
“r.cross -z --overwrite --quiet input=Connect_Lake@PERMANENT,str_grass_r@PERMANENT output=test”
But I got error by run r.cross in python with following command:
grass.run_command(‘r.cross’, input = [‘str_grass_r@PERMANENT’,‘Connect_Lake@PERMANENT’],output = ‘test’, quiet = True)
What is the correct format to use r.cross function in Python? and how to obtain the output table generated by r.cross?
Thanks
Ming
Please provide more information:
GRASS version
Python version
exact error message
I did not observe any errors while running command you provided (of
course I used different map names to match map names I had on my
system).
Māris.
otrd., 2020. g. 17. nov., plkst. 06:04 — lietotājs ming han
(<dustming@gmail.com>) rakstīja:
Hi Everyone
    "r.cross -z --overwrite --quiet input=Connect_Lake@PERMANENT,str_grass_r@PERMANENT output=test"
    grass.run_command('r.cross', input = ['str_grass_r@PERMANENT','Connect_Lake@PERMANENT'],output = 'test', quiet = True)
Thanks
Ming
On 11/17/20 6:03 AM, ming han wrote:
Hi Everyone
This worked fine for me also, using GRASS 7.8.4 in the nc_basin_spm LOCATION:
In [2]: import grass.script as gscript
In [3]: gscript.run_command("r.cross", input=["landuse@PERMANENT","basins@PERMANENT"], output="lu_bas", overwrite=True)
r.cross: STEP 1 ...
100%
r.cross: STEP 2 ...
r.cross: STEP 3 ...
100%
Creating support files for <lu_bas>...
89 categories
Out[3]: 0
Just to be clear, you do not get a table output, rather a raster. In your case you should see a new raster “test”.
Thanks
Ming
grass-user mailing list
[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
[https://lists.osgeo.org/mailman/listinfo/grass-user](https://lists.osgeo.org/mailman/listinfo/grass-user)
Micha Silver
Ben Gurion Univ.
Sde Boker, Remote Sensing Lab
cell: +972-523-665918
Hi Everyone
Thanks for your response, for some reason it works now.
Thanks
Ming
Micha Silver <tsvibar@gmail.com> 于2020年11月17日周二 上午10:44写道:
Hi Everyone
r.cross: STEP 1 ...
100%
r.cross: STEP 2 ...
r.cross: STEP 3 ...
100%
89 categories
Out[3]: 0
Thanks
Ming
Micha Silver
Ben Gurion Univ.
