Hi, maybe the grass-python bindings can help you ?
from grass, starting python :
In [1]: import grass.script as grass
In [2]: dict_region_info = dict(x.split('=', 1) for x in grass.read_command('r.info', flags = 'rstgudmp', map = 'elevation.10m').strip().replace('"','').replace('(','').replace(')','').split('\n') if '=' in x)
In [3]: dict_region_info
Out[3]:
{'datatype': 'DCELL',
'east': '609000',
'ewres': '10',
'max': '1846.743408',
'min': '1061.064087',
'north': '4928000',
'nsres': '10',
'south': '4914020',
'timestamp': 'none',
'title': ' elevation.10m',
'units': '(none)',
'vertical_datum': 'none',
'west': '590010'}
In [4]: dict_region_info['east']
Out[4]: '609000'
the code maybe needs little adjustmens, but it can give you an idea.
Il giorno 08/feb/2010, alle ore 11.36, António Rocha ha scritto:
Thank you Markus. I suppose, for now, it's enough to give me a clue about managing LANDSAT images
By the way, is there any specific command to retrieve a single information from metadata? I mean, r.info gives me a lot of information in a string.
from grass, start python :
Out[3]:
'east': '609000',
'ewres': '10',
'north': '4928000',
'nsres': '10',
'south': '4914020',
'units': '(none)',
'west': '590010'}
Out[4]: '609000'
Best regards
Antonio
Markus Neteler wrote:
2010/2/4 António Rocha <antonio.rocha@deimos.com.pt>:
Greetings all
I'm doing a few scripts that requires accessing LANDSAT/or other satellite
images channel header information (e.g. Gain/Bias). Is it possible to acess
that information through a Script file? I mean, having a script that
processes what I want and in the meanwhile uses some channel header values?
See
http://www.grassbook.org/examples_menu3rd.php
-> CHAPTER 8: Scripts to bulk import LANDSAT-TM5/LANDSAT-TM7 scenes
from GLCF Maryland into GRASS
* glcf_landsat7_for_NC_SPM_WAKE_process.sh (reproject, spatial
subset with GDAL)
* glcf_landsat5_for_NC_SPM_WAKE_import.sh (import into GRASS)
* glcf_landsat7_2000_for_NC_SPM_WAKE_import.sh (import into GRASS)
* glcf_landsat7_2002_for_NC_SPM_WAKE_import.sh (import into GRASS)
You can then use r.info to retrieve the metadata and use them for processing.
Hope this helps,
__________ Information from ESET NOD32 Antivirus, version of virus signature database 4847 (20100208) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
grass-dev mailing list
grass-dev@lists.osgeo.org
