I wonder if attached patch should be applied (quoting
of GISBASE path for white space).
(attachments)
grass_src.diff (1.09 KB)
Index: grass.src
# Set the GISBASE variable
-GISBASE=GISBASE_VALUE
+GISBASE="GISBASE_VALUE"
Yes.
This will matter if you want to install GRASS into e.g.
"C:\Program Files" on Windows and start GRASS via the grass63 bash
script rather than grass63.bat.
[The syntax of the command.com/cmd.exe "set" command is different;
everything after the = is the value, regardless of whitespace.]
> of GISBASE path for white space).> Index: grass.src
> +GISBASE="GISBASE_VALUE"Yes.
Done: submitted.
everything after the = is the value, regardless of whitespace.]--
