when I start GRASS from a Linux shell, going through Init.sh,
I can supply the name of a mapset and GRASS will automatically
log into that.
When I do the same in Windows, from cmd.exe and going through
Init.bat, I always get the interactive login screen. Is that
intented behaviour? Or is there something I am doing wrong with
the mapset path specification?
Linux:
grass64 $HOME/grassdb/test/usr
-> logs straight into mapset
Win:
grass64.bat c:\grassdb\test\user
-> goes to interactive login
Ben
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
In answer to myself:
Init.sh has this:
# User selects LOCATION and MAPSET if not set
if [ ! "$LOCATION" ] ; then
# Check for text interface
text)
"$ETC/set_data"
Whereas Init.bat just does:
:text
"%WINGISBASE%\etc\set_data"
So it will always go to the interactive login,
no matter if $LOCATION is already set or not.
Wouldn't it be a good idea to have both scripts
behave identically?
Ben
----- Original Message -----
log into that.
Linux:
Win:
Ben
