[GRASS-dev] [GRASS-SVN] r54852 - grass/trunk/lib/gis/colors
On Sat, Feb 2, 2013 at 11:26 PM, <svn_grass@osgeo.org> wrote:
Author: cmbarton
Date: 2013-02-02 14:26:41 -0800 (Sat, 02 Feb 2013)
New Revision: 54852
Modified:
   grass/trunk/lib/gis/colors/srtm_plus
Log:
update to srtm_plus colorable
+default 255:255:255
Usually there is not "default" specified, should it be there or not?
Markus Neteler wrote:
> Modified:
> Log:
or not?
Hi Markus,
I believe it does serve a purpose, perhaps when the color table
is based on fixed values instead of %, and does not extend far
enough to cover the range of the data, but the values are not
null either? In that case the default is white so the above may
be redundant.
best,
Hamish
I asked because it does not exist in any other table.
