2014-05-18 11:41 GMT+02:00 <svn_grass@osgeo.org>:
Author: hcho
Date: 2014-05-18 02:41:14 -0700 (Sun, 18 May 2014)
New Revision: 60309
Modified:
grass/trunk/vector/v.clean/main.c
Log:
v.clean: Option thresh => threshold
for record -- if you change option name that you should also note that
at dedicated trac page [1].
Thanks, Martin
[1] http://trac.osgeo.org/grass/wiki/Grass7/NewFeatures#Optionschanges
Yes, I’m doing it. I need time to login & type.
On Sun, May 18, 2014 at 5:46 AM, Martin Landa <landa.martin@gmail.com> wrote:
Author: hcho
New Revision: 60309
Modified:
Log:
for record – if you change option name that you should also note that
Thanks, Martin
