[GRASS-dev] [GRASS-SVN] r60596 - grass/trunk/vector/v.in.ogr
On Fri, May 30, 2014 at 12:46 AM, <svn_grass@osgeo.org> wrote:
Author: hcho
Date: 2014-05-29 21:46:55 -0700 (Thu, 29 May 2014)
New Revision: 60596
Modified:
   grass/trunk/vector/v.in.ogr/main.c
Log:
v.in.ogr: fallback datetime type for pg and dbf drivers
Modified: grass/trunk/vector/v.in.ogr/main.c
--- grass/trunk/vector/v.in.ogr/main.c 2014-05-30 04:01:53 UTC (rev 60595)
+++ grass/trunk/vector/v.in.ogr/main.c 2014-05-30 04:46:55 UTC (rev 60596)
@@ -103,6 +103,8 @@
     int OFTIntegerListlength;
     char *dsn;
+ const char *driver_name;
+ char *datetime_type;
     char *output;
     char **layer_names; /* names of layers to be imported
     int *layers; /* layer indexes */
@@ -336,9 +338,18 @@
        G_fatal_error(_("Required parameter <%s> not set"),
param.dsn->key);
+ driver_name = db_get_default_driver_name();
+ if (strcmp(driver_name, "pg") == 0)
+ datetime_type = G_store("timestamp with time zone");
+ else if (strcmp(driver_name, "dbf") == 0)
+ datetime_type = G_store("varchar(22)");
+ else
+ datetime_type = G_store("datetime");
     /* dsn is 'PG:', check default connection settings */
     dsn = NULL;
- if (strcmp(db_get_default_driver_name(), "pg") == 0 &&
+ if (strcmp(driver_name, "pg") == 0 &&
         G_strcasecmp(param.dsn->answer, "PG:") == 0) {
         const char *dbname;
         dbConnection conn;
@@ -1010,7 +1021,7 @@
                    sprintf(buf, ", %s time", Ogr_fieldname);
                else if (Ogr_ftype == OFTDateTime) {
- sprintf(buf, ", %s datetime", Ogr_fieldname);
+ sprintf(buf, ", %s %s", Ogr_fieldname, datetime_type);
#endif
                else if (Ogr_ftype == OFTString) {
grass-commit mailing list
grass-commit@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-commit
this revision broke running v.in.ogr during creating a new location with
Location Wizard based on georeferenced file (e.g. shapefile). User is asked
if he wants to also import the data into that location and then it fails
because v.in.ogr crashes. The problem is on line
driver_name seems to be NULL. Running the same v.in.ogr command after
starting normal grass session works. Is there and initialization missing?
Anna
On Fri, Sep 5, 2014 at 11:54 PM, Anna Petrášová <kratochanna@gmail.com>
Author: hcho
New Revision: 60596
Modified:
Log:
60595)
60596)
@@ -103,6 +103,8 @@
     char *dsn;
     char *output;
param.dsn->key);
+ else
     dsn = NULL;
         const char *dbname;
         dbConnection conn;
#endif
I added db.connect -c before importing the vector in gis_set.py. That seems
to solve it (r61815, and backported in r61816).
Anna
Glad to hear that you solved the issue. Even before this revision, strcmp(db_get_default_driver_name(), “pg”) was there… Anyway, I think initializing a database connection in the location wizard is the right way to fix it.
Thanks.
Huidae
On Sat, Sep 6, 2014 at 9:25 AM, Anna Petrášová <kratochanna@gmail.com> wrote:
grass-dev mailing list
grass-dev@lists.osgeo.org
On Fri, Sep 5, 2014 at 11:54 PM, Anna Petrášová <kratochanna@gmail.com> wrote:
I added db.connect -c before importing the vector in gis_set.py. That seems to solve it (r61815, and backported in r61816).
Author: hcho
New Revision: 60596
Modified:
Log:
— grass/trunk/vector/v.in.ogr/main.c 2014-05-30 04:01:53 UTC (rev 60595)
@@ -103,6 +103,8 @@
char *dsn;
  • const char *driver_name;
  • char *datetime_type;
    char *output;
    char *layer_names; / names of layers to be imported */
    int layers; / layer indexes */
    G_fatal_error(_(“Required parameter <%s> not set”), param.dsn->key);
  • driver_name = db_get_default_driver_name();
  • if (strcmp(driver_name, “pg”) == 0)
  • datetime_type = G_store(“timestamp with time zone”);
  • else if (strcmp(driver_name, “dbf”) == 0)
  • datetime_type = G_store(“varchar(22)”);
  • else
  • datetime_type = G_store(“datetime”);
/* dsn is ‘PG:’, check default connection settings */
dsn = NULL;
  • if (strcmp(db_get_default_driver_name(), “pg”) == 0 &&
  • if (strcmp(driver_name, “pg”) == 0 &&
    G_strcasecmp(param.dsn->answer, “PG:”) == 0) {
    const char *dbname;
    dbConnection conn;
    sprintf(buf, “, %s time”, Ogr_fieldname);
  • sprintf(buf, “, %s datetime”, Ogr_fieldname);
  • sprintf(buf, “, %s %s”, Ogr_fieldname, datetime_type);
    #endif
this revision broke running v.in.ogr during creating a new location with Location Wizard based on georeferenced file (e.g. shapefile). User is asked if he wants to also import the data into that location and then it fails because v.in.ogr crashes. The problem is on line
driver_name seems to be NULL. Running the same v.in.ogr command after starting normal grass session works. Is there and initialization missing?
Anna
On Sat, Sep 6, 2014 at 12:59 PM, Huidae Cho <grass4u@gmail.com> wrote:
strcmp(db_get_default_driver_name(), "pg") was there... Anyway, I think
to fix it.
I might have looked at wrong revision. Still, if the default db connection
is uninitialized, v.in.ogr would crash. I don't know if there is some other
case where this could happen, probably not.
Anna
Thanks.
Huidae
Author: hcho
New Revision: 60596
Modified:
Log:
60595)
60596)
@@ -103,6 +103,8 @@
     char *dsn;
     char *output;
imported */
param.dsn->key);
+ else
     dsn = NULL;
         const char *dbname;
         dbConnection conn;
datetime_type);
#endif
Anna
