[GRASS-dev] [GRASS-SVN] r60613 - in grass/trunk/vector: v.db.connect v.out.ascii v.rectify v.vect.stats
On Fri, May 30, 2014 at 11:54 AM, <svn_grass@osgeo.org> wrote:
- if (strcmp(delim_opt->answer, "\\t") == 0)
- *delim = G_store("\t");
About r60612 and r60613, they are great. But I just noted a changed
interface for some of the modules because they supported also `\t` for tab
besides `tab`.
Either parser should support this or this should go to the change of the
interface in 7 wiki page.
When we are on it what about \n, do we want this or not. I would say that
both \t and \n might be helpful but \n can be dangerous sometimes.
Hi, G_option_to_separator supports tab, \t, and newline. Do we need \n? I don’t think so because we can use newline. Maybe delete \t for consistency and use tab only?
  • if (strcmp(delim_opt->answer, “\t”) == 0)
  • *delim = G_store(“\t”);
About r60612 and r60613, they are great. But I just noted a changed interface for some of the modules because they supported also \t for tab besides tab.
Either parser should support this or this should go to the change of the interface in 7 wiki page.
When we are on it what about \n, do we want this or not. I would say that both \t and \n might be helpful but \n can be dangerous sometimes.
