[GRASS-dev] [GRASS-SVN] r60679 - grass/trunk/lib/python/script
Martin Landa wrote:
beside remaining compilation errors [1], wingrass 71 still (after
weeks!!!) even doesn't start...
Does anyone want to test the attached patch?
In particular, it needs to be tested with a Python script invoking an
exe with arguments containing characters which are likely to be
meaningful to the shell, including:
d.text or r.support may be useful as test cases.
But in the longer term, should we be claiming to support a platform
for which we appear to have no active developers?
(attachments)
popen-win.diff (1.04 KB)
2014-07-02 1:10 GMT+02:00 Glynn Clements <glynn@gclements.plus.com>:
I have locally applied the patch on the build server, result is
`r61114M-1010` [1], GRASS starts (welcome screen), unfortunately wxGUI
fails with
  File "C:\OSGEO4~1\apps\grass\grass-7.1.svn\gui\wxpython\wxgui.py", line 138,
n <module>
    sys.exit(main())
  File "C:\OSGEO4~1\apps\grass\grass-7.1.svn\gui\wxpython\wxgui.py", line 131,
n main
    app = GMApp(workspaceFile)
  File "C:\OSGEO4~1\apps\grass\grass-7.1.svn\gui\wxpython\wxgui.py", line 45, i
__init__
    wx.App.__init__(self, False)
  File "C:\OSGEO4~1\apps\Python27\lib\site-packages\wx-2.8-msw-unicode\wx\_core
py", line 7981, in __init__
    self._BootstrapApp()
py", line 7555, in _BootstrapApp
    return _core_.PyApp__BootstrapApp(*args, **kwargs)
  File "C:\OSGEO4~1\apps\grass\grass-7.1.svn\gui\wxpython\wxgui.py", line 79, i
OnInit
    workspace = self.workspaceFile)
  File "C:\OSGEO4~1\apps\grass\grass-7.1.svn\gui\wxpython\lmgr\frame.py", line
19, in __init__
    self._menuTreeBuilder = LayerManagerMenuData()
  File "C:\OSGEO4~1\apps\grass\grass-7.1.svn\gui\wxpython\lmgr\menudata.py", li
e 40, in __init__
    MenuTreeModelBuilder.__init__(self, filename, expandAddons=expandAddons)
  File "C:\OSGEO4~1\apps\grass\grass-7.1.svn\gui\wxpython\core\menutree.py", li
e 64, in __init__
    xmlTree = etree.parse(filename)
  File "C:\OSGEO4~1\apps\Python27\lib\xml\etree\ElementTree.py", line 1182, in
arse
    tree.parse(source, parser)
  File "C:\OSGEO4~1\apps\Python27\lib\xml\etree\ElementTree.py", line 657, in p
rse
    self._root = parser.close()
  File "C:\OSGEO4~1\apps\Python27\lib\xml\etree\ElementTree.py", line 1654, in
lose
    self._raiseerror(v)
  File "C:\OSGEO4~1\apps\Python27\lib\xml\etree\ElementTree.py", line 1506, in
raiseerror
    raise err
xml.etree.ElementTree.ParseError: no element found: line 1, column 0
The reason is empty XML wxGUI menu file (menudata.xml) produced by
building system, see [2].
  File "core/toolboxes.py", line 759, in <module>
    sys.exit(main())
  File "core/toolboxes.py", line 745, in main
    userDefined=False)
  File "core/toolboxes.py", line 204, in createTree
    moduleItems=moduleItems)
  File "core/toolboxes.py", line 241, in toolboxes2menudata
    _expandRuntimeModules(root)
  File "core/toolboxes.py", line 514, in _expandRuntimeModules
    desc, keywords = _loadMetadata(name)
  File "core/toolboxes.py", line 540, in _loadMetadata
    task = gtask.parse_interface(module)
  File "c:\osgeo4w\usr\src\grass_trunk\dist.i686-pc-mingw32\etc\python\grass\script\task.py",
line 501, in parse_interface
    tree = etree.fromstring(get_interface_description(name))
line 465, in get_interface_description
    stderr = PIPE)
  File "c:\osgeo4w\usr\src\grass_trunk\dist.i686-pc-mingw32\etc\python\grass\script\core.py",
line 58, in __init__
    name, ext = os.path.splitext(cmd)
  File "c:/OSGeo4W/apps/Python27\lib\ntpath.py", line 190, in splitext
    return genericpath._splitext(p, sep, altsep, extsep)
  File "c:/OSGeo4W/apps/Python27\lib\genericpath.py", line 91, in _splitext
    sepIndex = p.rfind(sep)
AttributeError: 'NoneType' object has no attribute 'rfind'
make[4]: *** [xml/menudata.xml] Error 1
Martin
[1] http://wingrass.fsv.cvut.cz/grass71/
[2] http://wingrass.fsv.cvut.cz/grass71/logs/log-r61114-1010/package.log
Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
On Wed, Jul 2, 2014 at 10:39 AM, Martin Landa <landa.martin@gmail.com>
    sys.exit(main())
    userDefined=False)
  File
  File
    stderr = PIPE)
  File
It seems that shutil_which returned None at line (from the patch):
cmd = shutil_which(args[0])
    sys.exit(main())
    userDefined=False)
  File
  File
    stderr = PIPE)
  File
_splitext
It's because it can't find v.in.gps. I suggest to add to the patch
something like this:
+ def __init__(self, args, **kwargs):
+ if ( sys.platform == 'win32'
+ and isinstance(args, list)
+ and not kwargs.get('shell', False)
+ and kwargs.get('executable') is None ):
+ cmd = shutil_which(args[0])
              if cmd is None:
                  raise OSError
+ args = [cmd] + args[1:]
+ name, ext = os.path.splitext(cmd)
+ if ext.lower() not in self._builtin_exts:
+ kwargs['shell'] = True
+ args = [self._escape_for_shell(arg) for arg in args]
+ subprocess.Popen.__init__(self, args, **kwargs)
grass-dev mailing list
grass-dev@lists.osgeo.org
On Wed, Jul 2, 2014 at 11:19 AM, Anna Petrášová <kratochanna@gmail.com>
    sys.exit(main())
    userDefined=False)
  File
  File
    stderr = PIPE)
  File
_splitext
              if cmd is None:
                  raise OSError
Otherwise the patch seems to work, I can run:
grass.run_command('r.support', map='mymap', title="|@#~$%^&*()><") in GUI
python console which was not possible before. r.info then gives correct
result.
Running this command in gui console works but r.info gives incorrect result:
r.support map=scanned title="|@#$%^&*()"
and r.info gives ^^^|@#$%^^^^^^^&*()
but gui command line functionality was not affected by this patch, it uses
different popen class, this is related to r60634 and following.
2014-07-02 17:19 GMT+02:00 Anna Petrášová <kratochanna@gmail.com>:
It's because it can't find v.in.gps. I suggest to add to the patch something like this:
thanks, I included modified patch to the next build n1011. Martin
              if cmd is None:
                  raise OSError
Hmm; maybe:
            if cmd is not None:
If shutil_which() doesn't find the command, we just leave it to
Popen() to complain about it. It's conceivable that it might even
manage to run it (I wouldn't assume that shutil_which() mimics
Windows' own handling exactly).
Ideally, I'd prefer our version of Popen to be as close to the
original as we can get away with.
Alternatively.
            if cmd is not None:
            else:
    name, ext = None, ''
In this case, it falls back to using the shell if shutil_which()
fails, while still keeping the shell out of the way for an EXE.
That implies that the GUI is escaping for the shell but then either
not using the shell or overdoing the escaping.
But I'm less concerned about the GUI than about the core grass.script
functionality.
On Wed, Jul 2, 2014 at 7:35 PM, Glynn Clements <glynn@gclements.plus.com>
Considering security issues connected to shell=True* and uncertainty of
escaping for MS Windows**, wouldn't be better to avoid shell=True and try
to use the right interpreter? This can work at least for the most common
(and probably only important) case which is Python.
Vaclav
* Now thinking about various WPS servers using GRASS, GIS systems using
GRASS, and potential WebGRASS.
** It seems that it will be hard to guess how to do it.
2014-07-02 20:54 GMT+02:00 Martin Landa <landa.martin@gmail.com>:
seems to be set forward, committed as r61135, feel free to improve. Martin
That's an option. Although if we use .bat files to execute Python
scripts, shutil_which() will find the .bat file rather than the script
itself.
If we hard-code the handling of Python scripts, it should only be done
for those which are part of GRASS (i.e. where the script is located in
a subdirectory of $GISBASE).
We would still need to fall back to using the shell for other
extensions.
Martin Landa wrote
2014-07-02 20:54 GMT+02:00 Martin Landa &lt;
landa.martin@
&gt;:
tested with:
GRASS 7.1.svn> g.version -g
version=7.1.svn
date=2014
revision=61158
build_date=2014-07-06
build_platform=i686-pc-mingw32
it fails with:
Launching <wxpython> GUI in the background, please wait...
GRASS 7.1.svn> Traceback (most recent call last):
  File "C:\OSGeo4W\apps\grass\grass-7.1.svn\gui\wxpython\wxgui.py", line
138, in
<module>
    sys.exit(main())
131, in
main
  File "C:\OSGeo4W\apps\grass\grass-7.1.svn\gui\wxpython\wxgui.py", line 45,
in
__init__
  File
"C:\OSGeo4W\apps\Python27\lib\site-packages\wx-2.8-msw-unicode\wx\_core.p
  File
  File "C:\OSGeo4W\apps\grass\grass-7.1.svn\gui\wxpython\wxgui.py", line 79,
in
OnInit
  File "C:\OSGeo4W\apps\grass\grass-7.1.svn\gui\wxpython\lmgr\frame.py",
line 12
1, in __init__
    self._moduleTreeBuilder = LayerManagerModuleTree()
  File "C:\OSGeo4W\apps\grass\grass-7.1.svn\gui\wxpython\lmgr\menudata.py",
line
62, in __init__
  File "C:\OSGeo4W\apps\grass\grass-7.1.svn\gui\wxpython\core\menutree.py",
line
66, in __init__
    expAddons(xmlTree)
  File "C:\OSGeo4W\apps\grass\grass-7.1.svn\gui\wxpython\core\toolboxes.py",
lin
e 271, in expandAddons
    _expandAddonsItem(root)
lin
e 431, in _expandAddonsItem
    addons = _getAddons()
lin
e 404, in _getAddons
    flags='a').splitlines())
  File "C:\OSGeo4W\apps\grass\grass-7.1.svn\gui\wxpython\core\gcmd.py", line
704
, in RunCommand
    ps = grass.start_command(GetRealCmd(prog), flags, overwrite, quiet,
verbose,
**kwargs)
  File
"C:\OSGeo4W\apps\grass\grass-7.1.svn\etc\python\grass\script\core.py", li
ne 354, in start_command
    return Popen(args, **popts)
  File
ne 58, in __init__
    raise OSError
OSError
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Re-GRASS-SVN-r60679-grass-trunk-lib-python-script-tp5143645p5149811.html
Sent from the Grass - Dev mailing list archive at Nabble.com.
On Sun, Jul 6, 2014 at 3:59 AM, Helmut Kudrnovsky <hellik@web.de> wrote:
Martin Landa wrote
> Hi,
> landa.martin@
> &gt;:
Martin
tested with:
version=7.1.svn
date=2014
revision=61158
it fails with:
138, in
<module>
    sys.exit(main())
131, in
main
45,
in
__init__
  File
  File
79,
in
OnInit
line 12
1, in __init__
line
62, in __init__
line
66, in __init__
    expAddons(xmlTree)
  File
lin
  File
lin
  File
lin
line
704
, in RunCommand
verbose,
**kwargs)
  File
  File
ne 58, in __init__
    raise OSError
OSError
It's because gui doesn't reflect recent changes by Martin. I temporarily
fixed it in r61171 but I don't really understand current status, is it
still work in progress? By the way the Popen class should be changed
according two Glynn's suggestions to let Popen throw the error.
Anna
best regards
Helmut
2014-07-07 21:58 GMT+02:00 Anna Petrášová <kratochanna@gmail.com>:
fixed it in r61171 but I don't really understand current status, is it still
work in progress? By the way the Popen class should be changed according two
feel free to implement Glynn's suggestions. I do not have time to try
to make WinGRASS 71 working again. Martin
On Sun, Jul 6, 2014 at 3:59 AM, Helmut Kudrnovsky &lt;
hellik@
ne 58, in __init__
    raise OSError
OSError
Anna
tested with:
System Info
GRASS Version: 7.1.svn
GRASS SVN Revision: 61180
Erstellungsdatum: 2014-07-08
Build Platform: i686-pc-mingw32
GDAL/OGR: 1.11.0
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
the GUI starts now, thanks.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Re-GRASS-SVN-r60679-grass-trunk-lib-python-script-tp5143645p5150047.html
> hellik@
li
>> ne 58, in __init__
>> raise OSError
>> OSError
> Anna
tested with:
System Info
GDAL/OGR: 1.11.0
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
g.gui.* modules are not found, there is no bat file created for them. Could
something similar to this be used for them as well? Otherwise everything
seems to be working.
http://trac.osgeo.org/grass/changeset/61136
Anna
best regards
Helmut
Could
Anna
g.gui.* which are linked in the main GUI are starting, but can't be invoked
in the wxGUI-command line.
also again, python addon scripts needs again bat-files in windows.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/Re-GRASS-SVN-r60679-grass-trunk-lib-python-script-tp5143645p5150331.html
2014-07-09 17:32 GMT+02:00 Helmut Kudrnovsky <hellik@web.de>:
also user-defined script will need bat files... Martin
