nice work! I was just trying it and I found a small error, see below
On Thu, Jun 5, 2014 at 1:32 PM, <svn_grass@osgeo.org> wrote:
Author: hcho
Date: 2014-06-05 10:32:48 -0700 (Thu, 05 Jun 2014)
New Revision: 60713Modified:
grass/trunk/include/gis.h
grass/trunk/lib/gis/parser.c
Log:
The “exclusive” member of the Option and Flag structures is a comma-separated
string. Whitespaces are not ignored. Each name separated by comma can be used
to group options/flags together, make them mutually exclusive, or make one of
them conditionally required.Names starting with “+” tie together options/flags and names starting with “*”
(name ignored) make them conditionally required (not always required, but if
some other options/flags are not used, they become required). Other names make
options/flags mutually exclusive in the same group. These three different types
of grouping can be mixed.EXAMPLES
- opt1 & opt2 are mutually exclusive.
opt2 & opt3 are mutually exclusive.opt1->exclusive = “1”;
opt2->exclusive = “1,2”;
opt3->exclusive = “2”;
- opt1 & opt2 must be used together.
opt1->exclusive = “+1”;
opt2->exclusive = “+1”;
opt3->exclusive = “”;
- opt1 or opt2 must be used. Both can be used together. Naming ignored.
opt1->exclusive = “ignored";
opt2->exclusive = "”;
- (opt1 & opt2 together) or (opt3 & opt4 together) must be used. All four can
be used together.opt1->exclusive = “+1,";
opt2->exclusive = “+1”; / * is optional because opt2 is tied with opt1 /
opt3->exclusive = "+2,”;
opt4->exclusive = “+2”;
It seems that the * is needed for both parameters (opt1 and opt2). When I have two types of inputs and one of them is required (exactly one) and I put * only to one of them (and they are in one group), I get this when I don’t specify any of them in the command line:
ERROR: One or more of the following options/flags must be used: or input2=
instead of
ERROR: One or more of the following options/flags must be used: input1= or input2=
- Only one of (opt1 & opt2 together) or (opt3 & opt4 together) must be used.
All four cannot be used together.opt1->exclusive = “+1,,1";
opt3->exclusive = "+2,,1”;
opt4->exclusive = “+2”; /* 1 is optional because opt4 is tied with opt3 */Modified: grass/trunk/include/gis.h
— grass/trunk/include/gis.h 2014-06-05 04:48:03 UTC (rev 60712)
+++ grass/trunk/include/gis.h 2014-06-05 17:32:48 UTC (rev 60713)
@@ -75,12 +75,12 @@
#define U_RADIANS 7
#define U_DEGREES 8
/* Temporal units from the datetime library */
-#define U_YEARS DATETIME_YEAR
-#define U_MONTHS DATETIME_MONTH
-#define U_DAYS DATETIME_DAY
-#define U_HOURS DATETIME_HOUR
-#define U_MINUTES DATETIME_MINUTE
-#define U_SECONDS DATETIME_SECOND
+#define U_YEARS DATETIME_YEAR
+#define U_MONTHS DATETIME_MONTH
+#define U_DAYS DATETIME_DAY
+#define U_HOURS DATETIME_HOUR
+#define U_MINUTES DATETIME_MINUTE
+#define U_SECONDS DATETIME_SECOND/*! \brief Projection code - XY coordinate system (unreferenced data) /
#define PROJECTION_XY 0
@@ -256,7 +256,7 @@
G_OPT_M_MAPSET, /!< mapset /
G_OPT_M_COORDS, /!< coordinates /
G_OPT_M_COLR, /!< color rules */
- G_OPT_M_DIR, /*!< directory input */
- G_OPT_M_DIR, /*!< directory input /
G_OPT_M_REGION, /!< saved region */G_OPT_STDS_INPUT, /*!< old input space time dataset of type strds, str3ds or stvds /
@@ -273,7 +273,7 @@
G_OPT_STVDS_OUTPUT, /!< new output space time vector dataset /
G_OPT_MAP_INPUT, /!< old input map of type raster, vector or raster3d /
G_OPT_MAP_INPUTS, /!< old input maps of type raster, vector or raster3d */
- G_OPT_STDS_TYPE, /*!< the type of a space time dataset: strds, str3ds, stvds */
- G_OPT_STDS_TYPE, /*!< the type of a space time dataset: strds, str3ds, stvds /
G_OPT_MAP_TYPE, /!< The type of an input map: raster, vect, rast3d /
G_OPT_T_TYPE, /!< The temporal type of a space time dataset /
G_OPT_T_WHERE, /!< A temporal GIS framework SQL WHERE statement /
@@ -393,15 +393,15 @@
/! \brief Resolution - east to west cell size for 2D data /
double ew_res;
/! \brief Resolution - east to west cell size for 3D data */
- double ew_res3;
- double ew_res3;
/*! \brief Resolution - north to south cell size for 2D data */
- double ns_res;
- double ns_res;
/*! \brief Resolution - north to south cell size for 3D data */
- double ns_res3;
- double ns_res3;
/*! \brief Resolution - top to bottom cell size for 3D data */
- double tb_res;
- double tb_res;
/*! \brief Extent coordinates (north) */
- double north;
double north;
/*! \brief Extent coordinates (south) /
double south;
/! \brief Extent coordinates (east) /
@@ -455,6 +455,8 @@
\brief Structure that stores option informationUsed by the G_parser() system.
The descriptions member contains pairs of option and option
descriptions separated by semicolon ‘;’.
For example, when options member is set using:
@@ -472,7 +474,61 @@
GUI dependency is a list of options (separated by commas) to be updated
if the value is changed.
- Used by the G_parser() system.
- The exclusive member of the Option and Flag structures is a comma-separated
- string. Whitespaces are not ignored. Each name separated by comma can be used
- to group options/flags together, make them mutually exclusive, or make one of
- them conditionally required. Names starting with “+” tie together
- options/flags and names starting with “*” (name ignored) make them
- conditionally required (not always required, but if some other options/flags
- are not used, they become required). Other names make options/flags mutually
- exclusive in the same group. These three different types of grouping can be
- mixed. G_parser() raises a fatal error if any violations are found.
- Examples
- opt1 & opt2 are mutually exclusive and opt2 & opt3 are mutually exclusive.
- \code
- opt1->exclusive = “1”;
- opt2->exclusive = “1,2”;
- opt3->exclusive = “2”;
- \endcode
- \code
- opt1->exclusive = “+1”;
- opt2->exclusive = “+1”;
- opt3->exclusive = “”;
- \endcode
- \code
- opt1->exclusive = “*ignored”;
- opt2->exclusive = “*”;
- \endcode
- can be used together.
- \code
- opt1->exclusive = “+1,*”;
- opt2->exclusive = “+1”; // * is optional because opt2 is tied with opt1
- opt3->exclusive = “+2,*”;
- opt4->exclusive = “+2”;
- \endcode
- All four cannot be used together.
- \code
- opt1->exclusive = “+1,*,1”;
- opt3->exclusive = “+2,*,1”;
- opt4->exclusive = “+2”; // 1 is optional because opt4 is tied with opt3
- \endcode
struct Option
{Modified: grass/trunk/lib/gis/parser.c
— grass/trunk/lib/gis/parser.c 2014-06-05 04:48:03 UTC (rev 60712)
+++ grass/trunk/lib/gis/parser.c 2014-06-05 17:32:48 UTC (rev 60713)
@@ -117,8 +117,13 @@
static void module_gui_wx(void);
static void add_exclusive(const char *, int, const char *);
static struct Exclusive *find_exclusive(char *);
+static int has_exclusive_name(const char *, char *);
static int has_exclusive_key(int, char **, char *);
-static void check_exclusive(int);
+static int has_either_or(const char *);
+static void check_exclusive();
+static void check_mutually_exclusive_inputs();
+static void check_tied_together_inputs();
+static void check_either_or_inputs();
static void append_error(const char *);/*!
@@ -550,7 +555,7 @@}
- check_exclusive(0);
- check_exclusive();
}/* Split options where multiple answers are OK */
@@ -902,6 +907,44 @@
return NULL;
}+static int has_exclusive_name(const char *names, char *name)
- char *ptr1;
- for (ptr1 = (char *)names; {
- int len;
- char *ptr2;
- for (len = 0, ptr2 = ptr1; *ptr2 != ‘\0’ && *ptr2 != ‘,’;
- ptr2++, len++) ;
- if (len > 0) { /* skip , */
- char *aname;
- aname = G_malloc(len + 1);
- memcpy(aname, ptr1, len);
- aname[len] = 0;
- if (strcmp(name, aname) == 0) {
- G_free(aname);
- return 1;
- G_free(aname);
- if (*ptr2 == ‘\0’)
- break;
- ptr1 = ptr2 + 1;
- if (*ptr1 == ‘\0’)
- break;
- return 0;
+}static int has_exclusive_key(int n_keys, char **keys, char *key)
int i;
@@ -914,87 +957,234 @@
return 0;
}-static void check_exclusive(int print_group)
+static int has_either_or(const char *names)
- int i, n, allocated, len;
- char **keys, *err;
- return names && (names[0] == '’ || strstr(names, ","));
- n = 0;
- allocated = 0;
- len = 0;
- keys = NULL;
- check_mutually_exclusive_inputs();
- check_tied_together_inputs();
- check_either_or_inputs();
+}+static void check_mutually_exclusive_inputs()
- int i;
for (i = 0; i < st->n_exclusive; i++) {
struct Exclusive *exclusive;exclusive = &st->exclusive[i];
- G_debug(1, “check_exclusive(): Exclusive option/flag group: %s”,
- exclusive->name);
- if (exclusive->name[0] == ‘+’ || exclusive->name[0] == ‘*’)
- continue;
- if (exclusive->n_keys >= 1)
- G_debug(1, “check_exclusive():\t%s”, exclusive->keys[0]);
- G_debug(1, "check_exclusive(): Mutually exclusive option/flag group: "
- “%s”, exclusive->name);
if (exclusive->n_keys > 1) {
- int j;
- int len, j;
- char *err;
- len = 0;
- for (j = 0; j < exclusive->n_keys; j++) {
- len += strlen(exclusive->keys[j]) + 2; /* 2 for comma adn space
- if (j > 0)
- G_debug(1, “check_exclusive():\t%s”, exclusive->keys[j]);
- err = G_malloc(len + 100);
- sprintf(err, _("The following options/flags cannot be used "
- "together: "));
- len = strlen(err);
- for (j = 0; j < exclusive->n_keys - 2; j++) {
- sprintf(err + len, "%s, ", exclusive->keys[j]);
- sprintf(err + len, _(“%s and %s”), exclusive->keys[j],
- exclusive->keys[j + 1]);
- append_error(err);
- G_free(err);
- if (print_group) {
- len = strlen(exclusive->name);
- space */
- if (j > 0)
- exclusive->keys[j]);
- int i;
- sprintf(err, _("Mutually exclusive options/flags "
- "in group ‘%s’: "), exclusive->name);
- for (i = 0; i < st->n_exclusive; i++) {
- struct Exclusive *exclusive;
- struct Option *opt;
- struct Flag *flag;
- int n, n_keys, len;
- char *err;
- exclusive = &st->exclusive[i];
- if (exclusive->name[0] != ‘+’)
- continue;
- G_debug(1, “check_exclusive(): Tied-together option/flag group: %s”,
- exclusive->name);
- n_keys = 0;
- len = 0;
- opt = &st->first_option;
- while (opt) {
- if (has_exclusive_name(opt->exclusive, exclusive->name)) {
- n_keys++;
- len += strlen(opt->key) + 3; /* 3 for =, comma and space */
- G_debug(1, “check_exclusive():\t%s=”, opt->key);
- else {
- if (!has_exclusive_key(n, keys, exclusive->keys[j])) {
- if (n >= allocated) {
- allocated += 10;
- keys = G_realloc(keys, allocated * sizeof(char *));
- keys[n] = exclusive->keys[j];
- len += strlen(keys[n++]) + 2; /* 2 for comma and space
- opt = opt->next_opt;
- flag = &st->first_flag;
- while (flag) {
- if (has_exclusive_name(flag->exclusive, exclusive->name)) {
- n_keys++;
- len += 4; /* 4 for -, flag, comma and space */
- G_debug(1, “check_exclusive():\t-%c”, flag->key);
}- flag = flag->next_flag;
if (!print_group && n) {
- if (n_keys == 1 || exclusive->n_keys == n_keys)
- continue;
- sprintf(err, _("Mutually exclusive options/flags: "));
sprintf(err, _("The following options/flags must be used together: "));
n = 0;
len = strlen(err);
- for (i = 0; i < n - 2; i++) {
- sprintf(err + len, "%s, ", keys[i]);
- while (opt) {
- n++;
- if (n <= n_keys - 2)
- sprintf(err + len, "%s=, ", opt->key);
- else if (n == n_keys - 1)
- sprintf(err + len, "%s= ", opt->key);
- else
- sprintf(err + len, “and %s=”, opt->key);
- sprintf(err + len, _(“%s and %s”), keys[i], keys[i + 1]);
- while (flag) {
- n++;
- sprintf(err + len, "-%c, ", flag->key);
- sprintf(err + len, "-%c ", flag->key);
- else
- sprintf(err + len, “and -%c”, flag->key);
append_error(err);
- G_free(err);
}+static void check_either_or_inputs()
- int n_keys, len;
- G_debug(1, "check_exclusive(): Either-or options/flags "
- “(group names ignored)”);
- n_keys = 0;
- len = 0;
- while (opt) {
- if (has_either_or(opt->exclusive)) {
- n_keys++;
- while (flag) {
- if (has_either_or(flag->exclusive)) {
- n_keys++;
- if (n_keys > 0) {
- int i;
- if (st->exclusive[i].name[0] == ‘*’)
- break;
- if (i == st->n_exclusive) {
- int n;
- char *err;
- sprintf(err, _("One or more of the following options/flags "
- "must be used: "));
- n = 0;
- while (opt) {
- n++;
- else
- sprintf(err + len, “or %s=”, opt->key);
- while (flag) {
- n++;
- else
- sprintf(err + len, “or -%c”, flag->key);
- G_free(err);
+}static void set_flag(int f)
struct Flag *flag;
grass-commit mailing list
grass-commit@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-commit
