[GRASS-dev] [GRASS-SVN] r61051 - grass/trunk/lib/init
Martin,
Please explain why we need this change. It breaks custom PS1 and aliases in $HOME/.grass7/bashrc.
Thank you.
Huidae
On Sun, Jun 29, 2014 at 6:22 AM, <svn_grass@osgeo.org> wrote:
Author: martinl
Date: 2014-06-29 03:22:23 -0700 (Sun, 29 Jun 2014)
New Revision: 61051
Modified:
grass/trunk/lib/init/grass.py
Log:
grass.py: do not override already set GRASS environmental variables
Modified: grass/trunk/lib/init/grass.py
— grass/trunk/lib/init/grass.py 2014-06-29 10:07:13 UTC (rev 61050)
+++ grass/trunk/lib/init/grass.py 2014-06-29 10:22:23 UTC (rev 61051)
@@ -746,7 +746,17 @@
k, v = map(lambda x: x.strip(), line.strip().split(’ ‘, 1)[1].split(’=', 1))
except:
continue
  • os.environ[k] = v
  • evalue = os.getenv(k)
  • if evalue:
  • if k == ‘GRASS_ADDON_PATH’:
  • os.environ[k] = evalue + os.pathsep + v
  • else:
  • warning(_(“Environmental variable ‘%s’ already set, ignoring value ‘%s’”) % \
  • (k, v))
  • else:
  • os.environ[k] = v
Allow for mixed ISIS-GRASS Environment
if os.getenv(‘ISISROOT’):
isis = os.getenv(‘ISISROOT’)
@@ -1131,8 +1141,14 @@
path = os.path.join(userhome, “.grass.bashrc”) # left for backward compatibility
if os.access(path, os.R_OK):
f.write(readfile(path) + ‘\n’)
  • if os.access(grass_env_file, os.R_OK):
  • f.write(readfile(grass_env_file) + ‘\n’)
  • for env in os.environ.keys():
  • if env.startswith(‘GRASS’):
  • val = os.environ[env]
  • if ’ ’ in val:
  • val = ‘“%s”’ % val
  • f.write(‘export %s=%s\n’ % (env, val))
f.write(“export PATH="%s"\n” % os.getenv(‘PATH’))
f.write(“export HOME="%s"\n” % userhome) # restore user home path
grass-commit mailing list
grass-commit@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-commit
Also, csh_startup() still overrides already set environment variables.
So we have $LOCATION/.bashrc, ~/.grass7/bashrc, and ~/.grass.bashrc. Do they all have different purposes and are they documented clearly somewhere?
On Fri, Jul 4, 2014 at 3:02 PM, Huidae Cho <grass4u@gmail.com> wrote:
Martin,
Thank you.
Huidae
Author: martinl
New Revision: 61051
Modified:
Log:
except:
continue
  • os.environ[k] = v
  • if evalue:
  • else:
  • (k, v))
  • else:
  • os.environ[k] = v
  • if ’ ’ in val:
2014-07-04 21:02 GMT+02:00 Huidae Cho <grass4u@gmail.com>:
sorry for late answer, the original reason was:
1) you have defined GRASS_ADDON_PATH in $HOME/.grass7/bashrc
2) you launch GRASS with $ GRASS_ADDON_PATH=~/bin/md-iso grass71
GRASS_ADDON_PATH points just to the path from `$HOME/.grass7/bashrc`.
The patch enables to merge paths from $HOME/.grass7/bashrc together
with `~/bin/md-iso`. I was not aware of aliases, you are absolutely
right, I will fix it ASAP. Martin
Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
2014-07-04 21:07 GMT+02:00 Huidae Cho <grass4u@gmail.com>:
`.grass.bashrc` is related to GRASS 6. GRASS 7 stores environmental
variables in `~/.grass7/bashrc`. The init script in GRASS 7 also reads
`.grass.bashrc` for backward compatibility. Martin
hopefully fixed in r61216. Martin
If that’s the only reason for this change, I would keep the previous version and let the user decide where to append GRASS_ADDON_PATH in ~/.grass7/bashrc.
  1. It’s breaking “export NEW_VAR=$HOME/grassdata” because $HOME doesn’t get expanded by bash.
  2. It’s inconsistent to append (“keep”) GRASS_ADDON_PATH and ignore other environment variables in ~/.grass7/bashrc.
  3. We should “not” simply ignore any environment variables in ~/.grass7/bashrc even if they already exist outside a GRASS session.
  4. grass.py is appending GRASS_ADDON_PATH in ~/.grass7/bashrc only “after” existing GRASS_ADDON_PATH. What if they want to append their path “before” the one in ~/.grass7/bashrc?
As to my original concern, even r61216 doesn’t allow overwriting PS1 initially created by grass.py. As a side effect of startswith(‘export’), I can work around it by appending whitespaces before export PS1=, but I would say that’s a bug, not a feature.
Anyway, my point is we can address the original issue by adding the following line in ~/.grass7/bashrc:
export GRASS_ADDON_PATH=“$GRASS_ADDON_PATH:~/grass-addon/bin”
This is more flexible and doesn’t impose “appending” of GRASS_ADDON_PATH and ignoring other variables in ~/.grass7/bashrc. In fact, like I said above in 1, the new version “breaks” this feature:
doesn’t expand to /home/user/grassdata.
IMHO, it should be the user’s responsibility and rights to overwrite or not overwrite anything available outside a GRASS session and that should happen in ~/.grass7/bashrc.
Best,
Huidae
On Wed, Jul 9, 2014 at 7:44 AM, Martin Landa <landa.martin@gmail.com> wrote:
  1. you have defined GRASS_ADDON_PATH in $HOME/.grass7/bashrc
  2. you launch GRASS with $ GRASS_ADDON_PATH=~/bin/md-iso grass71
GRASS_ADDON_PATH points just to the path from $HOME/.grass7/bashrc.
with ~/bin/md-iso. I was not aware of aliases, you are absolutely
export GRASS_ADDON_PATH="$GRASS_ADDON_PATH:~/grass-addon/bin"
I'm not following the discussion but this is the way how to work with
"PATH" variables. There is some equivalent in Python, I believe, with some
"path sep".
This is more flexible and doesn't impose "appending" of GRASS_ADDON_PATH
above in 1, the new version "breaks" this feature:
doesn't expand to /home/user/grassdata.
IMHO, it should be the user's responsibility and rights to overwrite or
I'm not sure if this is related but note that bash aliases and perhaps some
other things are not available in GRASS session and it is not considered as
an issue.
[GRASS-dev] Bash aliases in GRASS
http://lists.osgeo.org/pipermail/grass-dev/2013-February/061837.html
http://osgeo-org.1560.x6.nabble.com/Bash-aliases-in-GRASS-td5032707.html
[GRASS-user] loss of bash aliases
http://lists.osgeo.org/pipermail/grass-user/2008-March/043806.html
2014-07-09 17:44 GMT+02:00 Huidae Cho <grass4u@gmail.com>:
If that's the only reason for this change, I would keep the previous version
~/.grass7/bashrc.
you are probably right, reverted in r61273. Martin
