[GRASS-dev] [GRASS-SVN] r61363 - grass/branches/releasebranch_7_0/raster/r.in.gdal
Hi Markus,
On Wed, Jul 23, 2014 at 5:43 AM, <svn_grass@osgeo.org> wrote:
Author: neteler
Date: 2014-07-23 02:43:05 -0700 (Wed, 23 Jul 2014)
New Revision: 61363
Modified:
grass/branches/releasebranch_7_0/raster/r.in.gdal/main.c
Log:
r.in.gdal: GDALGetCacheMax() is limited to 2GiB, define valid range for memory parameter
Modified: grass/branches/releasebranch_7_0/raster/r.in.gdal/main.c
— grass/branches/releasebranch_7_0/raster/r.in.gdal/main.c 2014-07-23 09:33:12 UTC (rev 61362)
+++ grass/branches/releasebranch_7_0/raster/r.in.gdal/main.c 2014-07-23 09:43:05 UTC (rev 61363)
@@ -101,6 +101,7 @@
parm.memory->key = “memory”;
parm.memory->type = TYPE_INTEGER;
parm.memory->required = NO;
  • parm.memory->options = “0-2047”;
    parm.memory->description = _(“Cache size (MiB)”);
Any idea why 0-2047? r61362 message doesn’t explain and in fact is related to r61364. Shouldn’t options be changed to something like 1-, 0- or nothing? No reason to have upper limit, or is there some?
Vaclav
parm.target = G_define_option();
@@ -206,6 +207,7 @@
GDALAllRegister();
/* default GDAL memory cache size appears to be only 40 MiB, slowing down r.in.gdal */
if (parm.memory->answer && *parm.memory->answer) {
  • /* TODO: GDALGetCacheMax() overflows at 2GiB, implement use of GDALSetCacheMax64() */
    GDALSetCacheMax(atol(parm.memory->answer) * 1024 * 1024);
    G_verbose_message(_(“Using user memory cache size: %.1f MiB”), GDALGetCacheMax()/1024.0/1024.0);
    } else
grass-commit mailing list
grass-commit@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-commit
On Thu, Sep 24, 2015 at 5:51 PM, Vaclav Petras <wenzeslaus@gmail.com> wrote:
Hi Markus,
Author: neteler
New Revision: 61363
Modified:
Log:
memory parameter
--- grass/branches/releasebranch_7_0/raster/r.in.gdal/main.c 2014-07-23
@@ -101,6 +101,7 @@
     parm.memory->key = "memory";
+ parm.memory->options = "0-2047";
     parm.memory->description = _("Cache size (MiB)");
Any idea why 0-2047? r61362 message doesn't explain
See the "TODO" below.
to r61364. Shouldn't options be changed to something like 1-, 0- or nothing?
1? for 1 MiB?
Well, to avoid to crash the module... this is what I remember.
Vaclav
@@ -206,6 +207,7 @@
     GDALAllRegister();
down r.in.gdal */
+ /* TODO: GDALGetCacheMax() overflows at 2GiB, implement use of
            G_verbose_message(_("Using user memory cache size: %.1f MiB"),
     } else
