[GRASS-dev] [GRASS-SVN] r62026 - in grass/trunk: display/d.info include/defs lib/display
On Thu, Sep 18, 2014 at 12:43 AM, <svn_grass@osgeo.org> wrote:
Author: glynn
Date: 2014-09-17 15:43:22 -0700 (Wed, 17 Sep 2014)
New Revision: 62026
Modified:
   grass/trunk/display/d.info/main.c
   grass/trunk/include/defs/display.h
   grass/trunk/lib/display/r_raster.c
   grass/trunk/lib/display/setup.c
Log:
Change handling of display frame, graphical clip window
Replace D_get_window with D_get_frame
Add D_get_clip_window, D_set_clip_window
Add D_set_clip_window_to_map_window, D_set_clip_window_to_screen_window
Store initial frame size within display library
Change D_setup* functions to set graphical clip window
Should this be backported to relbr7?
Markus Neteler wrote:
> Author: glynn
> New Revision: 62026
> Modified:
> Log:
If the new behaviour is desirable[1], then yes.
http://lists.osgeo.org/pipermail/grass-dev/2014-September/070851.html
