On Sat, Sep 27, 2014 at 10:38 AM, Sören Gebbert <
soerengebbert@googlemail.com> wrote:
Hi Pietro,
thanks for the quick answer.
2014-09-27 16:28 GMT+02:00 Pietro <peter.zamb@gmail.com>:
> Hi Sören,
> On Sat, Sep 27, 2014 at 3:23 PM, Sören Gebbert
> <soerengebbert@googlemail.com> wrote:
>> I would like to directly link to the source code
>> docs, hence referencing temporal framework Python functions and
>> classes in this document. But i don't know how? Are there any code
>> examples howto link to Python library code?
> I'm not sure that I understand what you want, but I guess that you can
> use the label and then refer to them:
I want to reference classes and functions from the temporal framework
source code, since AFAIU is the source code documentation of the
temporal framework also created using sphinx?
For example, this class is located in lib/python/temporal/base.py
class SQLDatabaseInterface():
def __init_():
Howto reference this class in lib/python/docs/src/temporal.rst so that
i can click on the class name in the HTML docs to jump directly to the
source code documentation?
Bla bla bla :class:`SQLDatabaseInterface`
There is :class:`~gunittest.case.TestCase` in gunittest documentation, see
Sphinx documentation for details:
http://sphinx-doc.org/domains.html#cross-referencing-syntax
http://sphinx-doc.org/domains.html#cross-referencing-python-objects
http://sphinx-doc.org/markup/inline.html#xref-syntax
- You may supply an explicit title and reference target: :role:`title
<target>` will refer to *target*, but the link text will be *title*.
- If you prefix the content with !, no reference/hyperlink will be
created.
- If you prefix the content with ~, the link text will only be the last
component of the target. For example, :py:meth:`~Queue.Queue.get` will
refer to Queue.Queue.get but only display get as the link text.
The name enclosed in this markup can include a module name and/or a class
name. For example, :py:func:`filter` could refer to a function named filter
in the current module, or the built-in function of that name. In contrast,
:py:func:`foo.filter` clearly refers to the filter function in the foo
module.
If you prefix the name with a dot, this order is reversed. For example, in
the documentation of Python’s codecs module, :py:func:`open` always refers
to the built-in function, while :py:func:`.open` refers to codecs.open().
Note that you can combine the ~ and . prefixes: :py:meth:`~.TarFile.close`
will reference the tarfile.TarFile.close() method, but the visible link
caption will only be close().
Best regards
Soeren
grass-dev mailing list
grass-dev@lists.osgeo.org
