[GRASS-dev] [GRASS-SVN] r63924 - in grass/branches/releasebranch_7_0/general: g.list g.list/testsuite g.parser g.remove g.remove/testsuite g.setproj g.tempfile
On Thu, Jan 1, 2015 at 5:49 PM, <svn_grass@osgeo.org> wrote:
Author: neteler
Date: 2015-01-01 14:49:11 -0800 (Thu, 01 Jan 2015)
New Revision: 63924
Added:
   grass/branches/releasebranch_7_0/general/g.list/testsuite/
   grass/branches/releasebranch_7_0/general/g.list/testsuite/test_g_list.py
   grass/branches/releasebranch_7_0/general/g.remove/testsuite/
grass/branches/releasebranch_7_0/general/g.remove/testsuite/test_g_remove.py
Just to be sure that we know what we are doing. Are you planning to
backport gunittest? These tests are useless without it. If you just want to
reduce differences when using Meld then it is much more efficient to create
a file filter (Edit > Preferences > File Filters) in Meld. For example, I
have one named GRASS GIS which has OBJ.* bin.* dist.* in the pattern. You
can quickly turn on and off the filters in toolbar using Filters.
Author: neteler
New Revision: 63924
Added:
Just to be sure that we know what we are doing. Are you planning to backport
gunittest?
The test suite should definitely be backported in the near future
(perhaps not for 7.0.0).
These tests are useless without it. If you just want to reduce
differences when using Meld then it is much more efficient to create a file
filter (Edit > Preferences > File Filters) in Meld. For example, I have one
named GRASS GIS which has OBJ.* bin.* dist.* in the pattern. You can quickly
ok.
