[GRASS-dev] [GRASS-SVN] r64003 - grass-addons/grass7/vector/v.transects
Hi Anna,
On Thu, Jan 8, 2015 at 7:19 PM, <svn_grass@osgeo.org> wrote:
Author: annakrat
Date: 2015-01-08 10:19:01 -0800 (Thu, 08 Jan 2015)
New Revision: 64003
Modified:
   grass-addons/grass7/vector/v.transects/v.transects.html
   grass-addons/grass7/vector/v.transects/v.transects.py
Log:
v.transects: add l flag to create transect from the last point
Modified: grass-addons/grass7/vector/v.transects/v.transects.html
--- grass-addons/grass7/vector/v.transects/v.transects.html 2015-01-08 18:11:43 UTC (rev 64002)
+++ grass-addons/grass7/vector/v.transects/v.transects.html 2015-01-08 18:19:01 UTC (rev 64003)
@@ -3,6 +3,9 @@
<em>v.transects</em> creates equally spaced geometries along
input lines. The geometries can be lines or quadrilateral areas. Lines
and areas are generated to be perpendicular to the input line.
+By default the last point of each line is not used
+because the last transect distance would be typically different from the previous once.
+To create a transect from the last point, use flag <b>-l</b>.
<h2>NOTES</h2>
@@ -22,8 +25,8 @@
Location or the
<a href="http://courses.ncsu.edu/mea792/common/media/gisdemo.zip&quot;&gt;gisdemo (47MB)</a>
Location.
Just a small question... this is yet another location (never seen
before). How does it differ from
http://trac.osgeo.org/grass/wiki/SampleDataset#Downloadofdraftlocationpackage
-> LOCATION ncarolina_spm_base0.3.1.zip (40MB)
It would be nice to not have more than 2 of NC SPM (better only one).
thanks
On Thu, Jan 8, 2015 at 2:21 PM, Markus Neteler <neteler@osgeo.org> wrote:
Hi Anna,
> Author: annakrat
> New Revision: 64003
> Modified:
> Log:
> @@ -3,6 +3,9 @@
the previous once.
> <h2>NOTES</h2>
> @@ -22,8 +25,8 @@
> Location or the
(47MB)</a>
> Location.
Not sure but I removed it from there.
thanks
grass-dev mailing list
grass-dev@lists.osgeo.org
