On Tue, Jan 20, 2015 at 8:29 AM, <svn_grass@osgeo.org> wrote:
Fixed the flag.quiet structure issue
This should be replaced with G_verbose_message()
Thanks Vaclav,
will try.
Yann
On 20 January 2015 at 19:28, Vaclav Petras <wenzeslaus@gmail.com> wrote:
grass-dev mailing list
grass-dev@lists.osgeo.org
Hi Vaclav,
I have replaced all but one (in i.spec.sam/open.c):
if (!flag_quiet->answer)
m_output(A);
tentatively replaced by:
if (G_verbose == 3)
m_output(A);
is that OK?
Thanks
Yann
On 20 January 2015 at 20:15, Yann Chemin <ychemin@gmail.com> wrote:
Thanks Vaclav,
will try.
Yann
2015-01-20 16:04 GMT+01:00 Yann Chemin <ychemin@gmail.com>:
if (G_verbose == 3)
m_output(A);
}is that OK?
no, should be
if (G_verbose() > G_verbose_std())
Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.eu/mentors/landa
Thanks Martin, done in r64256
if (G_verbose == 3)
m_output(A);
}is that OK?
no, should be
Martin
Martin Landa
On Tue, Jan 20, 2015 at 10:04 AM, Yann Chemin <ychemin@gmail.com> wrote:
m_output(A);
It also depends on what the function is doing, for example if it is
outputting some map or time series, it could be a separate option.
