[GRASS-dev] [GRASS-SVN] r64407 - grass/trunk/gui/wxpython
2015-02-03 3:08 GMT+01:00 <svn_grass@osgeo.org>:
Author: wenzeslaus
Date: 2015-02-02 18:08:29 -0800 (Mon, 02 Feb 2015)
New Revision: 64407
Modified:
   grass/trunk/gui/wxpython/gis_set.py
Log:
wxGUI/startup: make warnings, hints and infos show the same; number boxes
thanks for improvements, unfortunately the window is behaving strange
when resizing. When I enlarge original screen (grass71_welcome.png)
and than resize to minimum size I get (grass71_welcome_resized.png).
It seems to be related only to wxPython 3.0 (tested on GNU/Linux). It
works perfectly with wxPython 2.8.
Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.eu/mentors/landa
(attachments)
On 06.02.2015 15:07, Martin Landa wrote:
Author: wenzeslaus
New Revision: 64407
Modified:
Log:
All this is tested only in the 71 version, right?
Nikos
2015-02-06 14:11 GMT+01:00 Nikos Alexandris <nik@nikosalexandris.net>:
yes, `grass71_` means grass 71 :slight_smile: No changes of startup screen has
been yet backported to relbr70.
Martin
Martin Landa
On Fri, Feb 6, 2015 at 2:07 PM, Martin Landa <landa.martin@gmail.com> wrote:
Author: wenzeslaus
New Revision: 64407
Modified:
Log:
I checked here with
GRASS 7.1.svn (eu_laea):~ > g.version -ge
version=7.1.svn
date=2015
revision=64482
build_date=2015-01-06
build_platform=x86_64-unknown-linux-gnu
proj4=4.8.0
gdal=1.11.1
geos=3.4.2
sqlite=3.8.8
rpm -qa | grep wxPython
wxPython-2.8.12.0-8.fc21.x86_64
and all is fine (just to confirm).
I dunno at which stage the wxPython 3 integration is in Fedora:
https://fedoraproject.org/wiki/Changes/wxPython3
Perhaps there is a docker image around for quick testing?
wrote:
> Hi,
>> Author: wenzeslaus
>> New Revision: 64407
>> Modified:
>> Log:
boxes
I can confirm that. I looked at that but so far nothing.
Anna
I checked here with
version=7.1.svn
date=2015
revision=64482
proj4=4.8.0
gdal=1.11.1
geos=3.4.2
sqlite=3.8.8
grass-commit mailing list
grass-commit@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-commit
