Hi, are you planing to backport it to relbr70? BTW, I was always
thinking about moving scripts which are duplicated in various branches
to one common place. Martin
2015-02-16 21:05 GMT+01:00 <svn_grass@osgeo.org>:
Author: wenzeslaus
Date: 2015-02-16 12:05:05 -0800 (Mon, 16 Feb 2015)
New Revision: 64658Modified:
grass/trunk/tools/grass_indent.sh
Log:
do not use tabs which are 8 spaces wide when indent level is 4 spacesIndent script was creating source code with 4 spaces for indent level 1,
1 tab for indent level 2, 1 tab and 4 spaces for indent level 3, 2 tabs
for indent level 4 etc. This is style which is hard to do manually
and cannot be easily guessed and supported by a text editor because it
mixes spaces and tabs
(http://lists.osgeo.org/pipermail/grass-dev/2014-September/070653.html).The indent rules are still the same, each level must be in multiplies
of 4 spaces (columns) as specified in
http://lists.osgeo.org/pipermail/grass-dev/2014-August/070497.html.No backwards compatibility is needed because just small portion of the
current code has no diff after applying the (original version of) indent
script. Now tested with v.external, i.segment and r.slope.aspect.The -ut (--use-tabs) was in the list at
https://trac.osgeo.org/grass/wiki/Submitting/C.
But it was not in the list at
http://grasswiki.osgeo.org/w/index.php?title=Development&oldid=21058#Explanation_of_C_indentation_rules.
And tabs are explicitly forbidden in instructions for Emacs users at
http://grasswiki.osgeo.org/w/index.php?title=GRASS_Programming_Howto&oldid=20573#Emacs.See also #1663 (Tabs in C source code) and grass-dev Tabs and spaces in C code
(http://lists.osgeo.org/pipermail/grass-dev/2014-August/070484.html).Modified: grass/trunk/tools/grass_indent.sh
--- grass/trunk/tools/grass_indent.sh 2015-02-16 19:48:39 UTC (rev 64657)
+++ grass/trunk/tools/grass_indent.sh 2015-02-16 20:05:05 UTC (rev 64658)
@@ -1,14 +1,28 @@
#!/bin/sh-# Indent source code according to GRASS SUBMITTING rules
+# Indent source code according to GRASS GIS submitting rules+# Should be in sync with:
+# https://trac.osgeo.org/grass/wiki/Submitting/C
+# http://grasswiki.osgeo.org/wiki/Development#Explanation_of_C_indentation_rules
+# Dependencies:
+# indent
+# Changes and their reasons:
+# -ts8 -ut -> --no-tabs
+# Do not use 8 space wide tabs when indent level is 4
+# TODO: replace short flags by long ones to improve readability
if [ $# -lt 1 ] ; then
echo "No files specified (give file name(s) as parameter)"
exit 1
else
indent -npro -bad -bap -bbb -br -bli0 -bls -cli0 -ncs -fc1 -hnl -i4 \
-nbbo -nbc -nbfda -nbfde -ncdb -ncdw -nce -nfca -npcs -nprs \
- -npsl -nsc -nsob -saf -sai -saw -sbi0 -ss -ts8 -ut "$@"
+ -npsl -nsc -nsob -saf -sai -saw -sbi0 -ss --no-tabs "$@"# fix broken gettext macros:
grep -l '\<_$' "$@" | \_______________________________________________
grass-commit mailing list
grass-commit@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-commit
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.eu/mentors/landa
