[GRASS-dev] [GRASS-SVN] r65249 - grass/trunk/raster/r.topidx
Hi, I see that you are making the indent in a file consistent but I just wanted to make sure you know that I recently updated the script ./tools/grass_indent.sh.
On Fri, May 15, 2015 at 11:42 AM, <svn_grass@osgeo.org> wrote:
Author: hcho
Date: 2015-05-15 08:42:52 -0700 (Fri, 15 May 2015)
New Revision: 65249
Modified:
grass/trunk/raster/r.topidx/main.c
grass/trunk/raster/r.topidx/topidx.c
Log:
r.topidx: indent
Modified: grass/trunk/raster/r.topidx/main.c
— grass/trunk/raster/r.topidx/main.c 2015-05-15 14:45:57 UTC (rev 65248)
+++ grass/trunk/raster/r.topidx/main.c 2015-05-15 15:42:52 UTC (rev 65249)
@@ -51,7 +51,7 @@
exit(EXIT_FAILURE);
/* Make sure that the current projection is not lat/long */
  • if ((G_projection() == PROJECTION_LL))
  • if (G_projection() == PROJECTION_LL)
    G_fatal_error(_(“Lat/Long location is not supported by %s. Please reproject map first.”),
    G_program_name());
Modified: grass/trunk/raster/r.topidx/topidx.c
— grass/trunk/raster/r.topidx/topidx.c 2015-05-15 14:45:57 UTC (rev 65248)
+++ grass/trunk/raster/r.topidx/topidx.c 2015-05-15 15:42:52 UTC (rev 65249)
@@ -125,7 +125,8 @@
sum += route[0];
nroute++;
  • if (!is_cv_null(i - 1, j) && cv(i, j) - cv(i - 1, j) > ZERO) {
  • cv(i, j) - cv(i - 1, j) > ZERO) {
    tanB[1] = (cv(i, j) - cv(i - 1, j)) * dx1;
    route[1] = 0.5 * dx * tanB[1];
    sum += route[1];
    @@ -148,7 +149,8 @@
    nroute++;
    if (j + 1 < window.cols) {
  • if (!is_cv_null(i, j + 1) && cv(i, j) - cv(i, j + 1) > ZERO) {
  • cv(i, j) - cv(i, j + 1) > ZERO) {
    tanB[5] = (cv(i, j) - cv(i, j + 1)) * dx1;
    route[5] = 0.5 * dx * tanB[5];
    sum += route[5];
    @@ -164,7 +166,8 @@
    sum += route[6];
    nroute++;
  • if (!is_cv_null(i + 1, j) && cv(i, j) - cv(i + 1, j) > ZERO) {
  • cv(i, j) - cv(i + 1, j) > ZERO) {
    tanB[7] = (cv(i, j) - cv(i + 1, j)) * dx1;
    route[7] = 0.5 * dx * tanB[7];
    sum += route[7];
    @@ -187,46 +190,38 @@
    nslp = 0;
    if (i > 0) {
    if (j > 0 && !is_cv_null(i - 1, j - 1)) {
  • sumtb += (cv(i - 1, j - 1)
    • cv(i, j)) * dx2;
  • sumtb += (cv(i - 1, j - 1) - cv(i, j)) * dx2;
    nslp++;
    if (!is_cv_null(i - 1, j)) {
  • sumtb += (cv(i - 1, j)
    • cv(i, j)) * dx1;
  • sumtb += (cv(i - 1, j) - cv(i, j)) * dx1;
    nslp++;
    if (j + 1 < window.cols && !is_cv_null(i - 1, j + 1)) {
  • sumtb += (cv(i - 1, j + 1)
    • cv(i, j)) * dx2;
  • sumtb += (cv(i - 1, j + 1) - cv(i, j)) * dx2;
    nslp++;
if (j > 0 && !is_cv_null(i, j - 1)) {
  • sumtb += (cv(i, j - 1)
    • cv(i, j)) * dx1;
  • sumtb += (cv(i, j - 1) - cv(i, j)) * dx1;
    nslp++;
    if (j + 1 < window.cols && !is_cv_null(i, j + 1)) {
  • sumtb += (cv(i, j + 1)
    • cv(i, j)) * dx1;
  • sumtb += (cv(i, j + 1) - cv(i, j)) * dx1;
    nslp++;
    if (i + 1 < window.rows) {
    if (j > 0 && !is_cv_null(i + 1, j - 1)) {
  • sumtb += (cv(i + 1, j - 1)
    • cv(i, j)) * dx2;
  • sumtb += (cv(i + 1, j - 1) - cv(i, j)) * dx2;
    nslp++;
    if (!is_cv_null(i + 1, j)) {
  • sumtb += (cv(i + 1, j)
    • cv(i, j)) * dx1;
  • sumtb += (cv(i + 1, j) - cv(i, j)) * dx1;
    nslp++;
    if (j + 1 < window.cols && !is_cv_null(i + 1, j + 1)) {
  • sumtb += (cv(i + 1, j + 1)
    • cv(i, j)) * dx2;
  • sumtb += (cv(i + 1, j + 1) - cv(i, j)) * dx2;
    nslp++;
grass-commit mailing list
grass-commit@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-commit
Hi, Thanks for pointing me to the script. I just manually adjusted several lines to make them 80 columns. Based on the script, it looks like couple options were dropped (-ts8, -ut) and new ones were added (-npro, --no-tabs).
Author: hcho
New Revision: 65249
Modified:
Log:
r.topidx: indent
@@ -51,7 +51,7 @@
exit(EXIT_FAILURE);
    G_program_name());
@@ -125,7 +125,8 @@
sum += route[0];
nroute++;
    sum += route[1];
    @@ -148,7 +149,8 @@
    nroute++;
    sum += route[5];
    @@ -164,7 +166,8 @@
    sum += route[6];
    nroute++;
    sum += route[7];
    nslp = 0;
    if (i > 0) {
    • cv(i, j)) * dx2;
    nslp++;
    • cv(i, j)) * dx1;
    nslp++;
    • cv(i, j)) * dx2;
    nslp++;
    • cv(i, j)) * dx1;
    nslp++;
    • cv(i, j)) * dx1;
    nslp++;
    • cv(i, j)) * dx2;
    nslp++;
    • cv(i, j)) * dx1;
    nslp++;
    • cv(i, j)) * dx2;
    nslp++;
-npro was there before. It prevents loading the user settings or something like that.
For the rest, see the relevant change set:
https://trac.osgeo.org/grass/changeset/64658
Author: hcho
New Revision: 65249
Modified:
Log:
r.topidx: indent
