Hi Soeren,
ich habe versucht, den relevanten Teil Deines fixes zu backporten:
https://trac.osgeo.org/grass/changeset/66115
Ich hoffe, dass es richtig ist..
Gruesse
On Tue, Aug 25, 2015 at 12:13 PM, <svn_grass@osgeo.org> wrote:
Author: huhabla
Date: 2015-08-25 03:13:30 -0700 (Tue, 25 Aug 2015)
New Revision: 66014Modified:
grass/trunk/lib/python/temporal/c_libraries_interface.py
grass/trunk/lib/python/temporal/core.py
grass/trunk/lib/python/temporal/space_time_datasets.py
Log:
temporal library: Fixed wrong mapset access methodModified: grass/trunk/lib/python/temporal/c_libraries_interface.py
--- grass/trunk/lib/python/temporal/c_libraries_interface.py 2015-08-25 10:03:10 UTC (rev 66013)
+++ grass/trunk/lib/python/temporal/c_libraries_interface.py 2015-08-25 10:13:30 UTC (rev 66014)
@@ -151,15 +151,17 @@:returns: Names of available mapsets as list of strings
count = 0
mapset_list =
try:
+ # Initilaize the accessable mapset list, this is bad C design!!!
+ libgis.G_get_mapset_name(0)
mapsets = libgis.G_get_available_mapsets()
while mapsets[count]:
char_list = ""
mapset = mapsets[count]
- if libgis.G_mapset_permissions(mapset) > 0:
+ if libgis.G_mapset_permissions(mapset) == 1 and libgis.G_is_mapset_in_search_path(mapset) == 1:
c = 0
while mapset[c] != "\x00":
char_list += mapset[c]
@@ -758,7 +760,7 @@
CALLBACK.argtypes = c_void_pcerror_handler = CALLBACK(error_handler)
libgis.G_add_error_handler(cerror_handler, None)# Crerate the function array
@@ -914,17 +916,17 @@
>>> mapset = ciface.get_mapset()
>>> location = ciface.get_location()
>>> gisdbase = ciface.get_gisdbase()
>>> ciface.fatal_error()
raise FatalError(message)
FatalError: Fatal error
@@ -950,7 +952,7 @@
self.start_server()
self.start_checker_thread()
self.stopThread = False
def start_checker_thread(self):
if self.checkThread is not None and self.checkThread.is_alive():
self.stop_checker_thread()
@@ -959,13 +961,13 @@
self.checkThread.daemon = True
self.checkThread.start()
def stop_checker_thread(self):
self.threadLock.acquire()
self.stopThread = True
self.threadLock.release()
self.checkThread.join(None)
def thread_checker(self):
"""Check every 200 micro seconds if the server process is alive"""
while True:
@@ -989,7 +991,7 @@def check_server(self):
self._check_restart_server()
def _check_restart_server(self):
"""Restart the server if it was terminated
@@ -1351,7 +1353,7 @@def fatal_error(self, mapset=None):
"""Generate a fatal error in libgis.
This function is only for testing purpose.
self.check_server()
@@ -1360,7 +1362,7 @@
return self.safe_receive("Fatal error")def safe_receive(self, message):
- """Receive the data and throw an FatalError exception in case the server
+ """Receive the data and throw an FatalError exception in case the server
process was killed and the pipe was closed by the checker thread"""
try:
ret = self.client_conn.recv()Modified: grass/trunk/lib/python/temporal/core.py
--- grass/trunk/lib/python/temporal/core.py 2015-08-25 10:03:10 UTC (rev 66013)
+++ grass/trunk/lib/python/temporal/core.py 2015-08-25 10:13:30 UTC (rev 66014)
@@ -750,7 +750,7 @@
stvds_tables_sql = stds_tables_template_sql.replace("STDS", "stvds")
str3ds_tables_sql = stds_tables_template_sql.replace("STDS", "str3ds")- msgr.message(_("Creating temporal database: %s" % (tgis_database_string)))
+ msgr.message(_("Creating temporal database: %s" % (str(tgis_database_string))))if tgis_backend == "sqlite":
# We need to create the sqlite3 database path if it does not exists
@@ -860,7 +860,7 @@
driver, dbstring = self.tgis_mapsets[mapset]if dbstring not in self.unique_connections.keys():
- self.unique_connections[dbstring] = DBConnection(backend=driver,
+ self.unique_connections[dbstring] = DBConnection(backend=driver,
dbstring=dbstring)self.connections[mapset] = self.unique_connections[dbstring]
@@ -1025,7 +1025,7 @@def __init__(self, backend=None, dbstring=None):
""" Constructor of a database connection
param backend:The database backend sqlite or pg
param dbstring: The database connection string
@@ -1071,7 +1071,7 @@
"""Connect to the DBMI to execute SQL statementsSupported backends are sqlite3 and postgresql
# Connection in the current mapsetModified: grass/trunk/lib/python/temporal/space_time_datasets.py
--- grass/trunk/lib/python/temporal/space_time_datasets.py 2015-08-25 10:03:10 UTC (rev 66013)
+++ grass/trunk/lib/python/temporal/space_time_datasets.py 2015-08-25 10:13:30 UTC (rev 66014)
@@ -88,7 +88,7 @@
>>> rmap.get_temporal_extent_as_tuple()
(datetime.datetime(2001, 1, 1, 0, 0), datetime.datetime(2012, 1, 1, 0, 0))
>>> rmap.get_name()
- 'strds_map_test_case'
+ u'strds_map_test_case'
>>> rmap.get_mapset() == mapset
True
>>> rmap.get_temporal_type()
@@ -407,7 +407,7 @@
>>> r3map.get_temporal_extent_as_tuple()
>>> r3map.get_name()
- 'str3ds_map_test_case'
+ u'str3ds_map_test_case'
>>> r3map.get_mapset() == mapset
True
>>> r3map.get_temporal_type()
@@ -737,7 +737,7 @@
>>> vmap.get_temporal_extent_as_tuple()
>>> vmap.get_name()
- 'stvds_map_test_case'
+ u'stvds_map_test_case'
>>> vmap.get_mapset() == mapset
True
>>> vmap.get_temporal_type()_______________________________________________
grass-commit mailing list
grass-commit@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-commit
