On Sat, Oct 10, 2015 at 8:00 PM, <svn_grass@osgeo.org> wrote:
Author: annakrat
Date: 2015-10-10 11:00:10 -0700 (Sat, 10 Oct 2015)
New Revision: 66466
Added:
grass/branches/releasebranch_7_0/scripts/r.import/
grass/branches/releasebranch_7_0/scripts/v.import/
Removed:
grass/branches/releasebranch_7_0/scripts/r.import/testsuite/
Modified:
grass/branches/releasebranch_7_0/scripts/Makefile
grass/branches/releasebranch_7_0/scripts/v.import/v.import.py
Log:
add v.import/r.import from trunk
There are a few differences between
grass70/scripts/v.import/v.import.py
grass71/scripts/v.import/v.import.py
... all on purpose? Just to be sure.
> Author: annakrat
> New Revision: 66466
> Added:
> Removed:
> Modified:
> Log:
Should be. v.in.ogr for some reason doesn't have -j in 71 and there are
changes in the interface because there is special widget in 71 which should
still be tested more.
grass-dev mailing list
grass-dev@lists.osgeo.org
