2015-11-09 12:47 GMT+01:00 <svn_grass@osgeo.org>:
Author: glynn
Date: 2015-11-09 03:47:38 -0800 (Mon, 09 Nov 2015)
New Revision: 66772
fyi, it seems that it broke travis builds [1]. Ma
add_col.c:2:27: fatal error: grass/dbstubs.h: No such file or directory
compilation terminated.
[1] https://s3.amazonaws.com/archive.travis-ci.org/jobs/90543352/log.txt
--- grass/trunk/db/drivers/dbf/dbdriver.h 2015-11-09 03:44:28 UTC (rev 66771)
+++ grass/trunk/db/drivers/dbf/dbdriver.h 2015-11-09 11:47:38 UTC (rev 66772)
@@ -1,22 +1,8 @@
-/* this file was automatically generated by ../mk_dbdriver_h.sh */
#ifndef DBDRIVER_H
#define DBDRIVER_H#include <grass/dbstubs.h>
-int db__driver_create_table();
-int db__driver_close_cursor();
-int db__driver_open_database();
-int db__driver_close_database();
-int db__driver_describe_table();
-int db__driver_init();
-int db__driver_finish();
-int db__driver_execute_immediate();
-int db__driver_fetch();
-int db__driver_get_num_rows();
-int db__driver_list_tables();
-int db__driver_open_select_cursor();
#define init_dbdriver() do{\
db_driver_create_table = db__driver_create_table;\
db_driver_close_cursor = db__driver_close_cursor;\Deleted: grass/trunk/db/drivers/mk_dbdriver_h.sh
--- grass/trunk/db/drivers/mk_dbdriver_h.sh 2015-11-09 03:44:28 UTC (rev 66771)
+++ grass/trunk/db/drivers/mk_dbdriver_h.sh 2015-11-09 11:47:38 UTC (rev 66772)
@@ -1,31 +0,0 @@
-#!/bin/sh
-# generates dbdriver.h
-tmp=mk_dbdriver_h.tmp.$$
-cat <<'EOT'> dbdriver.h
-#ifndef DBDRIVER_H
-#define DBDRIVER_H
-#include <grass/dbstubs.h>
-EOT
-grep -h '^\( *int *\)\?db__driver' *.c | sed \
- -e 's/^\( *int *\)*/int /' \
- -e 's/ *(.*$/();/' > $tmp
-cat $tmp >> dbdriver.h
-cat <<'EOT' >> dbdriver.h
-#define init_dbdriver() do{\
-EOT
-sed 's/^int *db__\([a-zA-Z_]*\).*$/db_\1 = db__\1;\\/' $tmp >> dbdriver.h
-cat <<'EOT'>> dbdriver.h
-}while(0)
-#endif
-EOT
-rm $tmpModified: grass/trunk/db/drivers/mysql/dbdriver.h
--- grass/trunk/db/drivers/mysql/dbdriver.h 2015-11-09 03:44:28 UTC (rev 66771)
+++ grass/trunk/db/drivers/mysql/dbdriver.h 2015-11-09 11:47:38 UTC (rev 66772)
@@ -1,25 +1,8 @@
#ifndef DBDRIVER_H
-int db__driver_begin_transaction();
-int db__driver_commit_transaction();
-int db__driver_create_index();
db_driver_close_cursor = db__driver_close_cursor;\Modified: grass/trunk/db/drivers/odbc/dbdriver.h
--- grass/trunk/db/drivers/odbc/dbdriver.h 2015-11-09 03:44:28 UTC (rev 66771)
+++ grass/trunk/db/drivers/odbc/dbdriver.h 2015-11-09 11:47:38 UTC (rev 66772)
@@ -1,24 +1,8 @@
#ifndef DBDRIVER_H
-int db__driver_list_databases();
-int db__driver_drop_table();
db_driver_close_cursor = db__driver_close_cursor;\Modified: grass/trunk/db/drivers/ogr/dbdriver.h
--- grass/trunk/db/drivers/ogr/dbdriver.h 2015-11-09 03:44:28 UTC (rev 66771)
+++ grass/trunk/db/drivers/ogr/dbdriver.h 2015-11-09 11:47:38 UTC (rev 66772)
@@ -1,21 +1,8 @@
#ifndef DBDRIVER_H
db_driver_open_database = db__driver_open_database;\Modified: grass/trunk/db/drivers/postgres/dbdriver.h
--- grass/trunk/db/drivers/postgres/dbdriver.h 2015-11-09 03:44:28 UTC (rev 66771)
+++ grass/trunk/db/drivers/postgres/dbdriver.h 2015-11-09 11:47:38 UTC (rev 66772)
@@ -1,30 +1,8 @@
#ifndef DBDRIVER_H
-int db__driver_create_database();
-int db__driver_delete_database();
-int db__driver_grant_on_table();
db_driver_close_cursor = db__driver_close_cursor;\Modified: grass/trunk/db/drivers/sqlite/dbdriver.h
--- grass/trunk/db/drivers/sqlite/dbdriver.h 2015-11-09 03:44:28 UTC (rev 66771)
+++ grass/trunk/db/drivers/sqlite/dbdriver.h 2015-11-09 11:47:38 UTC (rev 66772)
@@ -1,29 +1,8 @@
#ifndef DBDRIVER_H
db_driver_close_cursor = db__driver_close_cursor;\Modified: grass/trunk/lib/db/dbmi_driver/dbstubs.h
--- grass/trunk/lib/db/dbmi_driver/dbstubs.h 2015-11-09 03:44:28 UTC (rev 66771)
+++ grass/trunk/lib/db/dbmi_driver/dbstubs.h 2015-11-09 11:47:38 UTC (rev 66772)
@@ -1,102 +1,102 @@
-/* this file was automatically generated by mk_dbstubs_h.sh */
#ifndef DBSTUBS_H
#define DBSTUBS_H+extern int db__driver_add_column(dbString *, dbColumn *);
+extern int db__driver_bind_update(dbCursor *);
+extern int db__driver_close_cursor(dbCursor *);
+extern int db__driver_close_database(void);
+extern int db__driver_create_index(dbIndex *);
+extern int db__driver_create_table(dbTable *);
+extern int db__driver_create_database(dbHandle *);
+extern int db__driver_delete(dbCursor *);
+extern int db__driver_delete_database(dbHandle *);
+extern int db__driver_describe_table(dbString *, dbTable **);
+extern int db__driver_drop_column(dbString *, dbString *);
+extern int db__driver_drop_index(dbString *);
+extern int db__driver_drop_table(dbString *);
+extern int db__driver_execute_immediate(dbString *);
+extern int db__driver_fetch(dbCursor *, int, int *);
+extern int db__driver_find_database(dbHandle *, int *);
+extern int db__driver_finish(void);
+extern int db__driver_init(int, char **);
+extern int db__driver_insert(dbCursor *);
+extern int db__driver_list_indexes(dbString *, dbIndex **, int *);
+extern int db__driver_list_tables(dbString **, int *, int);
+extern int db__driver_list_databases(dbString *, int, dbHandle **, int *);
+extern int db__driver_open_insert_cursor(dbCursor *);
+extern int db__driver_open_select_cursor(dbString *, dbCursor *, int);
+extern int db__driver_open_update_cursor(dbString *, dbString *, dbCursor *, int);
+extern int db__driver_open_database(dbHandle *);
+extern int db__driver_grant_on_table(dbString *, int, int);
+extern int db__driver_get_num_rows(dbCursor *);
+extern int db__driver_begin_transaction(void);
+extern int db__driver_commit_transaction(void);
+extern int db__driver_update(dbCursor *);
#ifdef DB_DRIVER_C
-extern int db__driver_add_column();
-extern int db__driver_bind_update();
-extern int db__driver_close_cursor();
-extern int db__driver_close_database();
-extern int db__driver_create_index();
-extern int db__driver_create_table();
-extern int db__driver_create_database();
-extern int db__driver_delete();
-extern int db__driver_delete_database();
-extern int db__driver_describe_table();
-extern int db__driver_drop_column();
-extern int db__driver_drop_index();
-extern int db__driver_drop_table();
-extern int db__driver_execute_immediate();
-extern int db__driver_fetch();
-extern int db__driver_find_database();
-extern int db__driver_finish();
-extern int db__driver_init();
-extern int db__driver_insert();
-extern int db__driver_list_indexes();
-extern int db__driver_list_tables();
-extern int db__driver_list_databases();
-extern int db__driver_open_insert_cursor();
-extern int db__driver_open_select_cursor();
-extern int db__driver_open_update_cursor();
-extern int db__driver_open_database();
-extern int db__driver_grant_on_table();
-extern int db__driver_get_num_rows();
-extern int db__driver_begin_transaction();
-extern int db__driver_commit_transaction();
-extern int db__driver_update();
-int (*db_driver_add_column) () = db__driver_add_column;
-int (*db_driver_bind_update) () = db__driver_bind_update;
-int (*db_driver_close_cursor) () = db__driver_close_cursor;
-int (*db_driver_close_database) () = db__driver_close_database;
-int (*db_driver_create_index) () = db__driver_create_index;
-int (*db_driver_create_table) () = db__driver_create_table;
-int (*db_driver_create_database) () = db__driver_create_database;
-int (*db_driver_delete) () = db__driver_delete;
-int (*db_driver_delete_database) () = db__driver_delete_database;
-int (*db_driver_describe_table) () = db__driver_describe_table;
-int (*db_driver_drop_column) () = db__driver_drop_column;
-int (*db_driver_drop_index) () = db__driver_drop_index;
-int (*db_driver_drop_table) () = db__driver_drop_table;
-int (*db_driver_execute_immediate) () = db__driver_execute_immediate;
-int (*db_driver_fetch) () = db__driver_fetch;
-int (*db_driver_find_database) () = db__driver_find_database;
-int (*db_driver_finish) () = db__driver_finish;
-int (*db_driver_init) () = db__driver_init;
-int (*db_driver_insert) () = db__driver_insert;
-int (*db_driver_list_indexes) () = db__driver_list_indexes;
-int (*db_driver_list_tables) () = db__driver_list_tables;
-int (*db_driver_list_databases) () = db__driver_list_databases;
-int (*db_driver_open_insert_cursor) () = db__driver_open_insert_cursor;
-int (*db_driver_open_select_cursor) () = db__driver_open_select_cursor;
-int (*db_driver_open_update_cursor) () = db__driver_open_update_cursor;
-int (*db_driver_open_database) () = db__driver_open_database;
-int (*db_driver_grant_on_table) () = db__driver_grant_on_table;
-int (*db_driver_get_num_rows) () = db__driver_get_num_rows;
-int (*db_driver_begin_transaction) () = db__driver_begin_transaction;
-int (*db_driver_commit_transaction) () = db__driver_commit_transaction;
-int (*db_driver_update) () = db__driver_update;
+int (*db_driver_add_column) (dbString *, dbColumn *) = db__driver_add_column;
+int (*db_driver_bind_update) (dbCursor *) = db__driver_bind_update;
+int (*db_driver_close_cursor) (dbCursor *) = db__driver_close_cursor;
+int (*db_driver_close_database) (void) = db__driver_close_database;
+int (*db_driver_create_index) (dbIndex *) = db__driver_create_index;
+int (*db_driver_create_table) (dbTable *) = db__driver_create_table;
+int (*db_driver_create_database) (dbHandle *) = db__driver_create_database;
+int (*db_driver_delete) (dbCursor *) = db__driver_delete;
+int (*db_driver_delete_database) (dbHandle *) = db__driver_delete_database;
+int (*db_driver_describe_table) (dbString *, dbTable **) = db__driver_describe_table;
+int (*db_driver_drop_column) (dbString *, dbString *) = db__driver_drop_column;
+int (*db_driver_drop_index) (dbString *) = db__driver_drop_index;
+int (*db_driver_drop_table) (dbString *) = db__driver_drop_table;
+int (*db_driver_execute_immediate) (dbString *) = db__driver_execute_immediate;
+int (*db_driver_fetch) (dbCursor *, int, int *) = db__driver_fetch;
+int (*db_driver_find_database) (dbHandle *, int *) = db__driver_find_database;
+int (*db_driver_finish) (void) = db__driver_finish;
+int (*db_driver_init) (int, char **) = db__driver_init;
+int (*db_driver_insert) (dbCursor *) = db__driver_insert;
+int (*db_driver_list_indexes) (dbString *, dbIndex **, int *) = db__driver_list_indexes;
+int (*db_driver_list_tables) (dbString **, int *, int) = db__driver_list_tables;
+int (*db_driver_list_databases) (dbString *, int, dbHandle **, int *) = db__driver_list_databases;
+int (*db_driver_open_insert_cursor) (dbCursor *) = db__driver_open_insert_cursor;
+int (*db_driver_open_select_cursor) (dbString *, dbCursor *, int) = db__driver_open_select_cursor;
+int (*db_driver_open_update_cursor) (dbString *, dbString *, dbCursor *, int) = db__driver_open_update_cursor;
+int (*db_driver_open_database) (dbHandle *) = db__driver_open_database;
+int (*db_driver_grant_on_table) (dbString *, int, int) = db__driver_grant_on_table;
+int (*db_driver_get_num_rows) (dbCursor *) = db__driver_get_num_rows;
+int (*db_driver_begin_transaction) (void) = db__driver_begin_transaction;
+int (*db_driver_commit_transaction) (void) = db__driver_commit_transaction;
+int (*db_driver_update) (dbCursor *) = db__driver_update;
#else
-extern int (*db_driver_add_column) ();
-extern int (*db_driver_bind_update) ();
-extern int (*db_driver_close_cursor) ();
-extern int (*db_driver_close_database) ();
-extern int (*db_driver_create_index) ();
-extern int (*db_driver_create_table) ();
-extern int (*db_driver_create_database) ();
-extern int (*db_driver_delete) ();
-extern int (*db_driver_delete_database) ();
-extern int (*db_driver_describe_table) ();
-extern int (*db_driver_drop_column) ();
-extern int (*db_driver_drop_index) ();
-extern int (*db_driver_drop_table) ();
-extern int (*db_driver_execute_immediate) ();
-extern int (*db_driver_fetch) ();
-extern int (*db_driver_find_database) ();
-extern int (*db_driver_finish) ();
-extern int (*db_driver_init) ();
-extern int (*db_driver_insert) ();
-extern int (*db_driver_list_indexes) ();
-extern int (*db_driver_list_tables) ();
-extern int (*db_driver_list_databases) ();
-extern int (*db_driver_open_insert_cursor) ();
-extern int (*db_driver_open_select_cursor) ();
-extern int (*db_driver_open_update_cursor) ();
-extern int (*db_driver_open_database) ();
-extern int (*db_driver_grant_on_table) ();
-extern int (*db_driver_get_num_rows) ();
-extern int (*db_driver_begin_transaction) ();
-extern int (*db_driver_commit_transaction) ();
-extern int (*db_driver_update) ();
+extern int (*db_driver_add_column) (dbString *, dbColumn *);
+extern int (*db_driver_bind_update) (dbCursor *);
+extern int (*db_driver_close_cursor) (dbCursor *);
+extern int (*db_driver_close_database) (void);
+extern int (*db_driver_create_index) (dbIndex *);
+extern int (*db_driver_create_table) (dbTable *);
+extern int (*db_driver_create_database) (dbHandle *);
+extern int (*db_driver_delete) (dbCursor *);
+extern int (*db_driver_delete_database) (dbHandle *);
+extern int (*db_driver_describe_table) (dbString *, dbTable **);
+extern int (*db_driver_drop_column) (dbString *, dbString *);
+extern int (*db_driver_drop_index) (dbString *);
+extern int (*db_driver_drop_table) (dbString *);
+extern int (*db_driver_execute_immediate) (dbString *);
+extern int (*db_driver_fetch) (dbCursor *, int, int *);
+extern int (*db_driver_find_database) (dbHandle *, int *);
+extern int (*db_driver_finish) (void);
+extern int (*db_driver_init) (int, char **);
+extern int (*db_driver_insert) (dbCursor *);
+extern int (*db_driver_list_indexes) (dbString *, dbIndex **, int *);
+extern int (*db_driver_list_tables) (dbString **, int *, int);
+extern int (*db_driver_list_databases) (dbString *, int, dbHandle **, int *);
+extern int (*db_driver_open_insert_cursor) (dbCursor *);
+extern int (*db_driver_open_select_cursor) (dbString *, dbCursor *, int);
+extern int (*db_driver_open_update_cursor) (dbString *, dbString *, dbCursor *, int);
+extern int (*db_driver_open_database) (dbHandle *);
+extern int (*db_driver_grant_on_table) (dbString *, int, int);
+extern int (*db_driver_get_num_rows) (dbCursor *);
+extern int (*db_driver_begin_transaction) (void);
+extern int (*db_driver_commit_transaction) (void);
+extern int (*db_driver_update) (dbCursor *);
#endif#endif
Deleted: grass/trunk/lib/db/dbmi_driver/mk_dbstubs_h.sh
--- grass/trunk/lib/db/dbmi_driver/mk_dbstubs_h.sh 2015-11-09 03:44:28 UTC (rev 66771)
+++ grass/trunk/lib/db/dbmi_driver/mk_dbstubs_h.sh 2015-11-09 11:47:38 UTC (rev 66772)
@@ -1,29 +0,0 @@
-#!/bin/sh
-# generates dbstubs.h
-tmp=mk_dbstubs_h.tmp.$$
-cat <<'EOT'> dbstubs.h
-#ifndef DBSTUBS_H
-#define DBSTUBS_H
-#ifdef DB_DRIVER_C
-EOT
-grep -h '^\( *int *\)\?db__driver' ../stubs/*.c | sed \
- -e 's/^\( *int *\)*/extern int /' \
-cat $tmp >> dbstubs.h
-sed 's/^extern int *db__\([a-zA-Z_]*\).*$/int (*db_\1)() = db__\1;/' $tmp >> dbstubs.h
-cat <<'EOT'>> dbstubs.h
-#else
-EOT
-sed 's/^extern int *db__\([a-zA-Z_]*\).*$/extern int (*db_\1)();/' $tmp >> dbstubs.h
-#endif
-#endif
-EOT
-rm $tmpModified: grass/trunk/lib/db/stubs/open_update.c
--- grass/trunk/lib/db/stubs/open_update.c 2015-11-09 03:44:28 UTC (rev 66771)
+++ grass/trunk/lib/db/stubs/open_update.c 2015-11-09 11:47:38 UTC (rev 66772)
@@ -2,7 +2,7 @@int
db__driver_open_update_cursor(dbString * name, dbString * select,
- dbCursor * cursor, int *mode)
+ dbCursor * cursor, int mode)
db_procedure_not_implemented("db_open_update_cursor");
return DB_FAILED;_______________________________________________
grass-commit mailing list
grass-commit@lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-commit
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
