On Fri, Feb 12, 2016 at 11:34 PM, <svn_grass@osgeo.org> wrote:
Author: mlennert
Date: 2016-02-12 14:34:26 -0800 (Fri, 12 Feb 2016)
New Revision: 67819Modified:
grass-addons/grass7/vector/v.neighborhoodmatrix/v.neighborhoodmatrix.py
Log:
correctly read G_OPT_F_SEP options
I check GRASS + Addons for this change, there might be more candidates?
# core:
grep "options\['separator'" scripts/*/*
scripts/m.proj/m.proj.py: fs = options['separator']
scripts/r3.in.xyz/r3.in.xyz.py: fs = options['separator']
scripts/r.out.xyz/r.out.xyz.py:
separator=options['separator'])
scripts/r.tileset/r.tileset.py: fs = separator(options['separator'])
scripts/v.in.lines/v.in.lines.py: fs = separator(options['separator'])
# grass-addons:
general/g.rename.many/g.rename.many.py: sep = separator(options['separator'])
Should all make use of
grass.utils.separator(options['separator'])
