2016-03-15 9:56 GMT+01:00 <svn_grass@osgeo.org>:
Author: hcho
Date: 2016-03-15 01:56:28 -0700 (Tue, 15 Mar 2016)
New Revision: 68061
Modified:
grass/trunk/lib/gis/parser.c
Log:
G_recreate_command: Add empty answers.
Fix the command history for e.g., v.edit where="". Without this fix, where="" is not included, which makes an invalid command.
I tried to backport this commit to relbr70. My quick test:
v.random out=n n=100 --o
v.db.addtable n
leads to the all features removed.
v.edit n tool=delete where=""
Selecting features...
100 of 100 features selected from vector map <n@PERMANENT>
100 features deleted
I thought that this should be fixed by this commit, right? So no
features removed (?)
Thanks for explanation. Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
Hi Martin,
This fix only affects the history, not its behavior. “v.info -h n” gives you:
COMMAND: v.edit map=“n” layer=“1” type=“point,line,boundary,centroid” tool=“delete” threshold=-1,0,0 where=“” snap=“no”
Without this fix, you’ll see:
COMMAND: v.edit map=“n” layer=“1” type=“point,line,boundary,centroid” tool=“delete” threshold=-1,0,0 snap=“no”
and cannot reuse this command without manually adding where=“”.
BTW, I think v.edit n tool=delete where=“” should delete all features because you’re selecting all records by “select * from n” without any where conditions. So your results look OK.
Huidae
On Sun, May 1, 2016 at 4:51 PM, Martin Landa <landa.martin@gmail.com> wrote:
Author: hcho
New Revision: 68061
Modified:
Log:
Fix the command history for e.g., v.edit where=“”. Without this fix, where=“” is not included, which makes an invalid command.
v.db.addtable n
Selecting features…
100 of 100 features selected from vector map n@PERMANENT
Martin Landa
grass-dev mailing list
grass-dev@lists.osgeo.org
